Error Passing Objects to PageRank
Alechiove
Hi!
I'm trying to write down a program with buffers to perform PageRank algorithm.
The code that works with stl reads a csv with edges of the graph. Returns a std::vector<std::vector<int>>. Then, i flat that vector to a std::vector<int>.
The problem is in the lambda function that starts down the code for the ranks calculation. But i can't figure out if it is the vectors or some hyperparameters...
Can someone help me?
Here's the Code:
#include <sycl/sycl.hpp>
#include <sycl/ext/intel/fpga_extensions.hpp>
// #include <oneapi/mkl/blas.hpp>
#include <cmath>
#include <chrono>
#include <iostream>
#include <vector>
#include <cmath>
#include "guideline.h"
#include "print_vector.h"
#include "print_time.h"
#include "read_graph.h"
#include "flatVector.h"
using namespace sycl;
int main(int argc, char* argv[]){
    // Check CL Parameters
    if(argc < 5){
        // FAILURE
        guideline();
        return 0;
    else{
        // Parse CL Objects
        int device_selected = atoi(argv[1]);
        std::string csv_path = argv[2];
        float threshold = atof(argv[3]);
        float damping = atof(argv[3]);
        device d;
        // Select Accelerator
        if(device_selected == 1){
            d = device(cpu_selector()); //# cpu_selector returns a cpu device
        if(device_selected == 2){
            try {
                d = device(gpu_selector());      //# gpu_selector returns a gpu device
            } catch (exception const& e) {
                std::cout << "Cannot select a GPU\n" << e.what() << "\n";
                std::cout << "Using a CPU device\n";
        if(device_selected == 3){
            ext::intel::fpga_selector d;
        // Queue
        queue q(d);
        std::cout << "Device : " << q.get_device().get_info<info::device::name>() << "\n"; // print del device
        // Time for setup
        auto start_setup = std::chrono::steady_clock::now();
        // Graph Expressed by edges
        std::vector<std::vector<int>> graph = Read_graph(csv_path);/*edges of graph (Sparse matrix rep.)*/
        std::vector<int> flatGraph = flatten<int>(graph);
        // Calculation of # nodes
        int numNodes  = countNodes(graph);
        // Degree of Each node
        std::vector<int> degreesNodes = getDegrees(graph, numNodes+1);
        auto end_setup = std::chrono::steady_clock::now();
        // prints for debug
        print_time(start_setup, end_setup);
        // prints for debug
        //printVector<int>(degreesNodes);
        //Init - Final Vectors for ratings [R(t); R(t+1)]
        std::vector<float> ranks_t(numNodes, (float)(1.0/ (float)(numNodes)));
        std::vector<float> ranks_t_plus_one(numNodes);
        // Pagerank Execution Time
        auto start = std::chrono::steady_clock::now();
        buffer<int> bufferEdges(flatGraph.data(),flatGraph.size());
        buffer<float> bufferRanks(ranks_t.data(),ranks_t.size());
        buffer<int> bufferDegrees(degreesNodes.data(),degreesNodes.size());
        buffer<float> bufferRanksNext(ranks_t_plus_one.data(),ranks_t_plus_one.size());
        float distance = threshold + 1;
        while (distance > threshold) {
            q.submit([&](handler &h){
                auto accessorsEdges = bufferEdges.get_access<access::mode::read>(h);
                auto accessorsRanks = bufferRanks.get_access<access::mode::read>(h);
                auto accessorsDegrees = bufferDegrees.get_access<access::mode::read>(h);
                auto accessorsRanksNext = bufferRanksNext.get_access<access::mode::read_write>(h);
                h.parallel_for(range<1>(numNodes),[=] (id<1> i){// Errors not  device copiable
                    accessorsRanksNext[i] = (1.0 - damping) / numNodes;
                    int index_node_i;
                    int index_node_j;
                    for (int j = 0; j<flatGraph.size() / 2;j++) {
                        index_node_i = 2 * j;
                        index_node_j = index_node_i + 1;
                        if (accessorsEdges[index_node_j] == i) {
                            accessorsRanksNext[i] += damping * accessorsRanks[accessorsEdges[index_node_i]] / accessorsDegrees[accessorsEdges[index_node_i]];
            distance = 0;
            for (int i = 0; i < numNodes; i++) {
                distance += (ranks_t[i] - ranks_t_plus_one[i]) * (ranks_t[i] - ranks_t_plus_one[i]);
            distance = sqrt(distance);
            ranks_t_plus_one = ranks_t;
        auto end = std::chrono::steady_clock::now();
        // Print
        printVector(ranks_t_plus_one);
        std::cout<<std::endl<<std::endl<<std::endl;
        std::cout<<"Final Norm:\t"<<distance<<std::endl;
        // Print time PageRank
        print_time(start, end);
        return 0;
 Errors:
BUFFER_PageRank.cpp:34:24: warning: 'cpu_selector' is deprecated: Use the callable sycl::cpu_selector_v instead. [-Wdeprecated-declarations]
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/device_selector.hpp:74:21: note: 'cpu_selector' has been explicitly marked deprecated here
class __SYCL_EXPORT __SYCL2020_DEPRECATED(
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/detail/defines_elementary.hpp:52:40: note: expanded from macro '__SYCL2020_DEPRECATED'
#define __SYCL2020_DEPRECATED(message) __SYCL_DEPRECATED(message)
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/detail/defines_elementary.hpp:43:38: note: expanded from macro '__SYCL_DEPRECATED'
#define __SYCL_DEPRECATED(message) [[deprecated(message)]]
BUFFER_PageRank.cpp:38:28: warning: 'gpu_selector' is deprecated: Use the callable sycl::gpu_selector_v instead. [-Wdeprecated-declarations]
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/device_selector.hpp:62:21: note: 'gpu_selector' has been explicitly marked deprecated here
BUFFER_PageRank.cpp:42:28: warning: 'cpu_selector' is deprecated: Use the callable sycl::cpu_selector_v instead. [-Wdeprecated-declarations]
In file included from BUFFER_PageRank.cpp:1:
In file included from /glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/sycl.hpp:11:
In file included from /glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/accessor.hpp:25:
In file included from /glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/image.hpp:18:
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2440:3: error: static assertion failed due to requirement 'is_device_copyable<std::vector<int, std::allocator<int>>, void>::value || detail::IsDeprecatedDeviceCopyable<std::vector<int, std::allocator<int>>, void>::value': The specified type is not device copyable
  static_assert(is_device_copyable<FieldT>::value ||
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2438:7: note: in instantiation of template class 'sycl::detail::CheckFieldsAreDeviceCopyable<(lambda at BUFFER_PageRank.cpp:84:51), 4>' requested here
    : CheckFieldsAreDeviceCopyable<T, NumFieldsToCheck - 1> {
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2438:7: note: in instantiation of template class 'sycl::detail::CheckFieldsAreDeviceCopyable<(lambda at BUFFER_PageRank.cpp:84:51), 5>' requested here
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2438:7: note: in instantiation of template class 'sycl::detail::CheckFieldsAreDeviceCopyable<(lambda at BUFFER_PageRank.cpp:84:51), 6>' requested here
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2473:7: note: in instantiation of template class 'sycl::detail::CheckFieldsAreDeviceCopyable<(lambda at BUFFER_PageRank.cpp:84:51), 7>' requested here
    : CheckFieldsAreDeviceCopyable<FuncT, __builtin_num_fields(FuncT)>,
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2481:7: note: in instantiation of template class 'sycl::detail::CheckDeviceCopyable<(lambda at BUFFER_PageRank.cpp:84:51)>' requested here
    : CheckDeviceCopyable<KernelType> {};
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/handler.hpp:1251:5: note: in instantiation of template class 'sycl::detail::CheckDeviceCopyable<sycl::detail::RoundedRangeKernel<sycl::item<1, true>, 1, (lambda at BUFFER_PageRank.cpp:84:51)>>' requested here
    detail::CheckDeviceCopyable<KernelType>();
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/handler.hpp:1042:7: note: in instantiation of function template specialization 'sycl::handler::kernel_parallel_for_wrapper<sycl::detail::RoundedRangeKernel<sycl::item<1, true>, 1, (lambda at BUFFER_PageRank.cpp:84:51)>, sycl::item<1, true>, sycl::detail::RoundedRangeKernel<sycl::item<1, true>, 1, (lambda at BUFFER_PageRank.cpp:84:51)>>' requested here
      kernel_parallel_for_wrapper<KName, TransformedArgType>(Wrapper);
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/handler.hpp:1471:5: note: in instantiation of function template specialization 'sycl::handler::parallel_for_lambda_impl<sycl::detail::auto_name, (lambda at BUFFER_PageRank.cpp:84:51), 1>' requested here
    parallel_for_lambda_impl<KernelName>(NumWorkItems, std::move(KernelFunc));
BUFFER_PageRank.cpp:84:19: note: in instantiation of function template specialization 'sycl::handler::parallel_for<sycl::detail::auto_name, (lambda at BUFFER_PageRank.cpp:84:51)>' requested here
                h.parallel_for(range<1>(numNodes),[=] (id<1> i){// i vettori di interi non sono device copiable
/glob/development-tools/versions/oneapi/2023.0/oneapi/compiler/2023.0.0/linux/bin-llvm/../include/sycl/types.hpp:2440:51: note: expression evaluates to 'false || false'
3 warnings and 1 error generated.
 Here's also the rest of the codes for debugging if it helps:
FlatVector.h
#include <iostream>
#include <vector>
template<typename T>
std::vector<T> flatten(const std::vector<std::vector<T>>& nestedVector) {
    std::vector<T> flatVector;
    for (const auto& subVector : nestedVector) {
        for (const auto& element : subVector) {
            flatVector.push_back(element);
    return flatVector;
read_graph.h
#include <iostream>
#include <fstream>
#include <sstream>
#include <vector>
// #include "print_vector.h"
std::vector<int> getDegrees(const std::vector<std::vector<int>> &graph, int numNodes) {
    std::vector<int> degrees(numNodes);
    for (auto &edge : graph) {
        ++degrees[edge[0]];
        ++degrees[edge[1]];
    return degrees;
std::vector<std::vector<int>> Read_graph(std::string file_name){
    // Apertura del file
    std::ifstream file(file_name);
    if (!file.is_open()) {
        std::cerr << "Impossibile aprire il file" << std::endl;
        return {};
    // Lettura del file riga per riga
    std::string line;
    std::vector<std::vector<int>> graph;
    while (getline(file, line)) {
        std::stringstream ss(line);
        std::string cell;
        std::vector<int> edge;
        while (getline(ss, cell, ',')) {
            edge.push_back(stoi(cell));
        graph.push_back(edge);
    file.close();
    return graph;
int countNodes(std::vector<std::vector<int>> graph){
    int numNodes = 0;
    for(auto &i : graph){
        for(auto &j : i){
            numNodes = std::max(numNodes, j);
    return numNodes;
guideline.h
#include <iostream>
void guideline(){
    std::cout<<"Not enough input parameters!\n\n";
    std::cout<<"Usage guide:\n\n";
    std::cout<<"First parameter:\tDevice code (as int number)\n";
    std::cout<<"\t\t1: CPU\n";
    std::cout<<"\t\t2: GPU\n";
    std::cout<<"\t\t3: FPGA\n";
    std::cout<<"Second parameter:\tCsv path of the dataset\n";
    std::cout<<"Available Ones:\n\n";
    std::cout<<"\t\t\"datasets/cit-Patents.csv\""<<std::endl;
    std::cout<<"\t\t\"datasets/soc-LiveJournal1.csv\""<<std::endl;
    std::cout<<"\t\t\"datasets/twitter-2010.csv\""<<std::endl;
    std::cout<<"\t\t\"datasets/web-uk-2005-all.csv\""<<std::endl;
    std::cout<<"Third parameter:\tThreshold (float value)\n";
    std::cout<<"Fourth parameter:\tDamping (float value)\n";
 printTime.h
#include <iostream>
#include <chrono>
void print_time(std::chrono::time_point<std::chrono::steady_clock> start, std::chrono::time_point<std::chrono::steady_clock> end){
    std::cout << "Elapsed time in nanoseconds: " << std::chrono::duration_cast<std::chrono::nanoseconds>(end - start).count() << " ns" << std::endl;
    std::cout << "Elapsed time in microseconds: " << std::chrono::duration_cast<std::chrono::microseconds>(end - start).count() << " µs" << std::endl;
    std::cout << "Elapsed time in milliseconds: " << std::chrono::duration_cast<std::chrono::milliseconds>(end - start).count() << " ms" << std::endl;
    std::cout << "Elapsed time in seconds: " << std::chrono::duration_cast<std::chrono::seconds>(end - start).count() << " sec" << std::endl;
SeshaP_Intel
Could you please try calculating the flatGraph size outside the while loop block using the below command?
auto fd=flatGraph.size();
Hope this resolves your issue. Please let us know if you still face any issues.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
Thanks and Regards,
Alechiove
Yes, it Worked! thank you so much
SeshaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
