Error running vector-add on NVIDIA GPU
John_Johnson
Hello everyone!
This thread is related to https://software.intel.com/en-us/forums/oneapi-data-parallel-c-compiler/topic/850410?language=en-us&https=1 and I wanted to write there, but post was locked.
My problem is that when running vector-add example on NVIDIA Tesla P100 example I get error:
Command I run:
$ SYCL_DEVICE_TYPE=GPU SYCL_DEVICE_WHITE_LIST="" SYCL_DEVICE_ALLOWLIST="" ./vector-add
Device: Tesla P100-PCIE-12GB
terminate called after throwing an instance of 'cl::sycl::runtime_error'
  what():  OpenCL API failed. OpenCL API returns: -34 (CL_INVALID_CONTEXT) -34 (CL_INVALID_CONTEXT)
Does someone have any about that?
RahulV_intel
Hi John,
Could you try running this sample on CPU and let us know if the issue persists?
What version of oneAPI base-toolkit are you using?
--Rahul
John_Johnson
On CPU inteloneapi works just fine. Command I use to run on CPU:
$ SYCL_DEVICE_TYPE=CPU ./vector-add
Device: Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
success
* My IntelOneApi version is beta04
GouthamK_Intel
Hi John,
Intel oneAPI currently doesn't support NVIDIA GPU's.
Goutham
John_Johnson
Hmmm... I checked here and I see that it should support NVIDIA GPU's:
https://www.phoronix.com/scan.php?page=news_item&px=Codeplay-Does-SYCL-On-NVIDIA
GouthamK_Intel
Hi John,
Currently, Intel oneAPI basekit beta04 doesn't support Nvidia GPU's.
The link which you referred is Codeplay's distribution of oneAPI So you may need to install it separately and work on it.
Goutham
GouthamK_Intel
We hope the resolution provided helped you.
In case of any further queries please feel free to raise a new thread.
Goutham
