872 Discussions
Exception when trying OneAPÌ Base Toolkit for the first time
clicia
Dear all,
I installed OneAPI base toolkit and Visual Studio 2019 (communit) on a laptop with Windows 10. I'm trying to run some samples using the OneAPI command prompt.
The first example I tried to run was the vector-add. Compilation seems to work, but the execution returns the following error:
An exception is caught while adding two vectors.
NMAKE : fatal error U1077: '.\vector-add-usm.exe' : return code '0xc0000409'
Stop.
This appears for both the buffered and the USM version. Are there any recommendations to work around this issue?
clicia
 I saw that there is an update of oneAPI Base Toolkit to version 2021.3.
After reinstalling the new version the problem no longer appears.
Thank you for all attention.
MRajesh_intel
After creating the vector-add project in your specified directory (for USM):
1) Build the program using the following 'nmake' command:
nmake -f Makefile.win build_usm
2) Run the program using:
nmake -f Makefile.win run_usm
(if you instead use run, the error occurs)
Please refer to the README.md file in your vector-add project and let us know if you have any issues.
Rajesh.
clicia
Hi Rajesh,
The problem persists.
I will specify the step by step I followed:
1) Open oneAPI command prompt for Intel 64 for Visual Studio 2019
2) Type oneapi-cli
3) Create a project (sample language: cpp; Sample: Base: Vector Add)
4) Go to project folder
5) Type: nmake -f Makefile.win build_usm
6) Type: nmake -f Makefile.win run_usm
The output for commands 5 and 6 is below:
C:\Temp\30-vector-add>nmake -f Makefile.win build_usm
Microsoft (R) Program Maintenance Utility Version 14.29.30037.0
Copyright (C) Microsoft Corporation. All rights reserved.
dpcpp -O2 -EHsc -Zi -o vector-add-usm.exe src/vector-add-usm.cpp
C:\Temp\30-vector-add>nmake -f Makefile.win run_usm
vector-add-usm.exe
Stop.
MRajesh_intel
We were unable to reproduce this issue on our side. Can you please specify the oneAPI version and Visual studio version?
Rajesh.
MRajesh_intel
Can you please provide the above mentioned details?
Rajesh.
clicia
Hi
  • Intel® oneAPI Base Toolkit for Windows* (all tools): version 2021.2
  • Visual Studio 2019: version 16.10
Thank you.
clicia
MRajesh_intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh
