887 Discussions
How could we use struct including vector or array
jimbook_
struct obj {
  int* arr;
  int size;
struct obj {
  vector<int> arr;
  int size;
 I want to build  a struct like above, but sycl may not allow these struct. The first struct contains a point, So these data  to which the pointer points cannot be copied to device. The second struct contains a vector, but at code of device I am not able to  get data using subscripts.
The quesition is how can I build a struct with same  functional which can be used on the device.
RabiyaSK_Intel
We haven't heard back from you. Were the sample codes that we provided able to resolve your issue?
If you still face any issues, you can reach out to us.
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
We can build structures with both array pointer member and vector member in SYCL code which can be used on device.
We've tried a sample code using structures with both array pointer and vector members and we received expected outputs.
Please refer to the attached zip file for the sample codes that we have tried.
Also please refer to the below screenshots for the results.
For structure with pointer array member:
For structure with vector member:
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
Could you please let us know whether your issue is resolved as you accepted it as a solution?
If your issue isn't resolved, please reach out to us.
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
I hope your issue is resolved. If you need any additional information, you can raise a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Shaik Rabiya
