How to use XMX with dpcpp on Xe-HPG
might
hi,as I mentioned bolow,I know that there are XMXs on Xe-HPG,which are used to do GEMM,but I don't know how to use it explicitly with dpcpp .could you give me some help, please.
NoorjahanSk_Intel
You can use it using experimental oneAPI extension, joint_matrix from DPC++ extension, sycl_ext_oneapi_matrix.
Please refer to the below link for more details:
https://github.com/intel/llvm/blob/sycl/sycl/doc/extensions/experimental/sycl_ext_oneapi_matrix.asciidoc
Please refer to the below link for a sample program:
https://github.com/intel/llvm-test-suite/blob/intel/SYCL/Matrix/joint_matrix_bfloat16.cpp
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
might
Thank you very much for your reply, it was very helpful to me。
thanks again
NoorjahanSk_Intel
Thanks for accepting our solution.
As this issue has been resolved, we will no longer respond to this thread. If you need any additional information, please post a new question
Thanks & Regards,
Noorjahan.
