836 Discussions
I can't build and run a sample vector-add program
hardcore_cat
I did everything as described on this page, and after the command
Build the program using Make.
cd vector-add
make all
I get this error, I attached a photo
Fedora 35 oneapi base toolkit
What else do i need to download and install?
PriyanshuK_Intel
Could you please provide us with the below details to investigate more on your issue?
 1. The Base toolkit version.
 2. The steps you followed in order to download oneAPI Base Toolkit.
Thanks & Regards
Priyanshu.
PriyanshuK_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards
Priyanshu.
PriyanshuK_Intel
It seems like the "cstddef" file is missing from your system, you could try on a system that has that file.
As we have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Priyanshu.
