Implementing multiple functions in kernel
student4
Shown below is my DPC++ code.
I want to call the function Add within the kernel scope. I want the function add to be implemented by the kernel and not by the host. Is it doable using dpc++.
Thank you.
#include <iostream>
#include<vector>
#include<random>
#include<omp.h>
#include<chrono>
#include <CL/sycl.hpp>
#include <ext/intel/fpga_extensions.hpp>
using namespace std;
void Oneapi_Fpga()
vector<float>testData(10);
vector<float>filterCoeff(5);
int convLen = testData.size() + filterCoeff.size() - 1;
vector<float>convSeq(convLen);
std::random_device rand;
std::mt19937 generator(rand());
std::normal_distribution<float> ndist{ 0.0f, 1.0f };
for (int i = 0; i < testData.size(); i++)
testData[i] = ndist(generator);
std::random_device randi;
std::mt19937 generatorr(randi());
std::normal_distribution<float> ndisti{ 0.0f, 1.0f };
for (int i = 0; i < filterCoeff.size(); i++)
filterCoeff[i] = ndisti(generator);
int lenA = 10;
int lenB = 5;
int nconv;
std::chrono::high_resolution_clock::time_point t6, t7;
std::chrono::duration<double, std::milli> accum3;
accum3 = std::chrono::milliseconds(0);
nconv = lenA + lenB - 1;
vector<float>C(nconv);
// FPGA oneapi implementation
sycl::buffer testBuff(testData);
sycl::buffer filterBuff(filterCoeff);
sycl::buffer convBuff(C);
sycl::ext::intel::fpga_emulator_selector d_selector;
try
cl::sycl::queue Q(d_selector);
t6 = std::chrono::high_resolution_clock::now();
Q.submit([&](sycl::handler& h)
sycl::accessor testAccess(testBuff, h, sycl::read_only);
sycl::accessor filterAccess(filterBuff, h, sycl::read_only);
sycl::accessor cAccess(convBuff, h, sycl::read_write);
h.single_task([=]() {
for (int i = 0; i < nconv; i++)
int i1 = i;
float tmp = 0.0;
for (int j = 0; j < lenB; j++)
if (i1 >= 0 && i1 < lenA)
tmp = tmp + (testAccess[i1] * filterAccess[j]);
i1 = i1 - 1;
cAccess[i] = tmp;
Add(cAccess);        // function should be implemented by kernel
t7 = std::chrono::high_resolution_clock::now();
Q.wait_and_throw();
catch (sycl::exception const& e)
std::cout << "Caught a SYCL host exception:\n" << e.what() << "\n";
sycl::host_accessor cHost(convBuff);
accum3 = t7 - t6;
cout << "time taken by FPGA oneapi implementation is" << accum3.count() << endl;
int main()
for(int i=0;i<1000000;i++)
Oneapi_Fpga();
std::cout << "success\n";
NoorjahanSk_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan.
Klaus-Dieter_O_Intel
I assume you are looking for something like (see also https://oneapi-src.github.io/DPCPP_Reference/model/kernel-programming-model.html
void Add( sycl::accessor<float, 1, sycl::access::mode::read_write> cAccess ){
  int nconv = cAccess.size();
  for (int i = 0; i < nconv; i++){
   cAccess[i] *= nconv;
