827 Discussions
Intel C++ compiler warning when using isnan/isinf
Dan78
Hi all,
I have observed recently (I am using latest update of Intel compilers i.e., version Intel(R) oneAPI DPC++/C++ Compiler 2024.1.0 (2024.1.0.20240308)) that icpx returns warning when compiling a simple code that used "isnan" std function and the warning is:
warning: explicit comparison with NaN in fast floating point mode [-Wtautological-constant-compare]
The code I use for testing is:
#include <iostream>
#include <complex>
#include <cmath>
using namespace std;
int main() {
 int xxx;
 xxx = sqrt(-1);
 auto b = std::isnan(xxx);
 cout << "b is: " << b << endl;
 return 0;
Is there any way to modify my code to avoid getting this warning? GNU compilers do not show such warning.
Dan
Viet_H_Intel
DPC++/C++ compiler is LLVM base. So, clang++ should give a warning on the same code as well.
For floating point, fast mode is on by default with icpx
If you don't want to see the warning message, you can compile with -fp-model strict/precise or with -Wno-tautological-constant-compare flag.
Here is link to clang++ https://godbolt.org/z/bv746h51r
Viet
Viet_H_Intel
Viet
Dan78
Thanks a lot. I had included "-fp-model precise" in the Makefile but I had to change it to "-fp-model=precise" and now the warning is gone.
