855 Discussions
Issue regarding the usage of ap_float datatype
HariG
I've recently stumbled across arbitrary precision datatype called ap_float, but I'm unable to use it.
Compilation says header file not found.
Error messageError messageHeader fileHeader file
any help would be greatly Appreciated.
SeshaP_Intel
Could you please try by adding the below option to the existing command while running the code and let us know your findings?
-I "/opt/intel/oneapi/compiler/latest/linux/lib/oclfpga/include/"
Please let us know whether your issue is resolved or not. If not please provide the follow‌ing details:
1. Complete reproducer code with the steps you have followed.
2. On which device you want to offload the code.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks and Regards,
SeshaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
