844 Discussions
Malibou Lake Software build error - Re upload
hyeongilee99
Sorry, I think I uploaded my query to the wrong category. Therefore, re-upload.
Hi, I'm working on the build guide in document 816867. I'm almost done with the build, but when I build with bitbake core-image-sato, I get the following error:
ERROR: zlib-native-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts/native-intercept:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin/x86_64-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: zlib-native-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/x86_64-linux/zlib-native/1.2.13-r0/temp/log.do_fetch.14754 ERROR: Task (virtual:native:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1' WARNING: lib32-zlib-1.2.13-r0 do_fetch: Failed to fetch URL https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers, attempting MIRRORS if available ERROR: lib32-zlib-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/bin/i686-pokymllib32-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/lib32-recipe-sysroot/usr/bin/crossscripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: lib32-zlib-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/core2-32-pokymllib32-linux/lib32-zlib/1.2.13-r0/temp/log.do_fetch.14796 ERROR: Task (virtual:multilib:lib32:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1' WARNING: zlib-1.2.13-r0 do_fetch: Failed to fetch URL https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers, attempting MIRRORS if available ERROR: zlib-1.2.13-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/scripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/bin/x86_64-poky-linux:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot/usr/bin/crossscripts:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/usr/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/sbin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/recipe-sysroot-native/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/poky/bitbake/bin:/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/hosttools"; export HOME="/home/intel"; /usr/bin/env wget -w 10 -c -t 5 --waitretry=10 -T 360 -nv --passive-ftp --no-check-certificate --hsts-file=/home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/.wget-hsts -P /home/intel/yocto_build/OS/LINUX/YOCTO/build/downloads 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers' --progress=dot -v failed with exit code 8, no output ERROR: zlib-1.2.13-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://git.yoctoproject.org/poky/plain/meta/recipes-core/zlib/site_config/headers;name=headers') ERROR: Logfile of failure stored in: /home/intel/yocto_build/OS/LINUX/YOCTO/build/tmp/work/corei7-64-poky-linux/zlib/1.2.13-r0/temp/log.do_fetch.14773 ERROR: Task (/home/intel/yocto_build/OS/LINUX/YOCTO/poky/../meta-intel-automotive/recipes-core/zlib/zlib_1.2.13.bb:do_fetch) failed with exit code '1'
  • Operating system with its build version.
  • Exact name and version of the of Intel® Toolkit.
    • MBL_2417_EXTERNAL
  • Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
    • There is no installed Intel Parallel Studio XE or Intel® oneAPI. I couldn't find any instructions in the documentation to pre-install that software.
  • Screenshot of the error (if possible)
    • Screenshots and log files are attached.
cpu info:
intel@4dd25ff3da7a:~$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 85
model name : Intel(R) Xeon(R) Gold 6234 CPU @ 3.30GHz
stepping : 7
microcode : 0x5003605
cpu MHz : 3300.000
cache size : 25344 KB
physical id : 0
siblings : 16
core id : 8
cpu cores : 8
apicid : 16
initial apicid : 16
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l3 cdp_l3 invpcid_single intel_ppin ssbd mba ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm mpx rdt_a avx512f avx512dq rdseed adx smap clflushopt clwb intel_pt avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm ida arat pln pts hwp hwp_act_window hwp_epp hwp_pkg_req pku ospke avx512_vnni md_clear flush_l1d arch_capabilities
vmx flags : vnmi preemption_timer posted_intr invvpid ept_x_only ept_ad ept_1gb flexpriority apicv tsc_offset vtpr mtf vapic ept vpid unrestricted_guest vapic_reg vid ple shadow_vmcs pml ept_mode_based_exec tsc_scaling
bugs : apic_c1e spectre_v1 spectre_v2 spec_store_bypass swapgs taa itlb_multihit mmio_stale_data retbleed eibrs_pbrsb gds bhi
bogomips : 6600.00
clflush size : 64
cache_alignment : 64
address sizes : 46 bits physical, 48 bits virtual
power management:
Alex_Y_Intel
What exactly were you trying to build? What compiler did you use?
hyeongilee99
I am doing a yocto BSP build for Malibou Lake SW. Please refer to documents 816866 and 816867.
The compiler list is as attached.
Alex_Y_Intel
We don't know what documents 816866 and 816867 are.
From the screenshot you provided, you used gcc. Whey did you post gcc problem on Intel's DPC++/C++ compiler forum?
Karolina_S_Intel
Hi hyeongilee99,
Please open an IPS (https://intel.lightning.force.com/) ticket to properly support your request for MBL questions. If you don't have access please contact your Intel representative.
