891 Discussions
No error line numbers when using oneAPI c++ compiler with Visual Studio
NoahB
I am using the oneAPI 2025 C++ compiler with Visual Studio 2022. The Intel compiler is not showing file names or line numbers in the Error List. The Error List only shows the error and the associated project. This works normally for projects compiled with the Microsoft compiler. Only projects using the Intel compiler have this issue. Is there a way to enable this feature when using the Intel compiler?
yzh_intel
hi, can you please provide an example to reproduce this issue, e.g. the source code, project file etc ?
