underflow for mixing signed and unsigned,
The comparison then fails.
I know it is my fault for mixing unsigned and signed.
But std::vector returns a size_type, which in turn is a template of something. I struggled finding the definition, but I assume it is an unsigned of something.
if((size() - 9) >= 0) // underflow
(-1) >= 0 // TRUE ?!
When I wrote the code I didnt think about it.
If I store the result temporarily in a signed int it works fine.
Below is a PoC
The result of the subtraction is probably expanded to the unsigned datatype.
But then the comparison >= doesn't make sense.
It is always true
The string "First" is printed but not "Second".
I think it would help if we get a warning about signed/unsigned mismatch in the comparison, or always true condition. I am compiling with Intel DPC++ 2025 on Windows.
$icpx t12.cpp &&./a.out
First!
$ icpx t12.cpp -Wsign-conversion
t12.cpp:8:19: warning: implicit conversion changes signedness: 'int' to 'size_type' (aka 'unsigned long') [-Wsign-conversion]
8 | if ((v.size() - adjustIndex) >= 0) {
t12.cpp:11:26: warning: implicit conversion changes signedness: 'int' to 'size_type' (aka 'unsigned long') [-Wsign-conversion]
11 | int index = v.size() - adjustIndex;
2 warnings generated.
$ icpx t12.cpp -Wtautological-unsigned-zero-compare
t12.cpp:8:32: warning: result of comparison of unsigned expression >= 0 is always true [-Wtautological-unsigned-zero-compare]
1 warning generated.
$ cat t12.cpp
#include <iostream>
#include <vector>
using namespace std;
int main()
std::vector<char> v(8);
int adjustIndex = 9;
printf("First!\n");
if (index >= 0) {
printf("Second!\n");
return 0;
We are not using the same compiler or platform. a.out is un*x filename
I am using Visual Studio 2022, DPC++, under Windows.
Compiler is set to use Warning level 3 -W3, -Wall doesn't detect it either
Can you try -Weverything? or -Wsign-conversion -Wtautological-unsigned-zero-compare in VS
Now we are talking
It seems the compiler it is using is clang to compile.
"C:\\Program Files (x86)\\Intel\\oneAPI\\compiler\\2025.0\\bin\\compiler\\clang-cl.exe"
If I add "-Wno-error -Wsign-conversion -Wtautological-unsigned-zero-compare"
or -Weverything the warning rightfully appears.
It seems that Visual Studio passes "-Wall" as option to clang too on the command line.
"-Wall" is usually enough for most development.
Reading https://clang.llvm.org/docs/UsersManual.html#options-to-control-error-and-warning-messages
"Since -Weverything enables every diagnostic, we generally don’t recommend using it. -Wall -Wextra are a better choice for most projects. "
Adding "-Wextra" also shows the warnings, but it seems that "-Wall" doesn't catch the error.
