832 Discussions
OneAPI Way to Check the Number of CPU cores/threads in use?
bxbxf
 I was wondering if there is a way, when I run a sycl program with a cpu_selector to get if I'm using it as single core or multi core ?
Using sycl::info::device::max_compute_units. Here's a minimal example:
#include <CL/sycl.hpp>
#include <iostream>
int main(){
  sycl::device d = sycl::cpu_selector().select_device();
  std::cout << d.get_info<sycl::info::device::max_compute_units>() << std::endl;
On my machine (which has 8 physical cores & 16 hardware threads), this returns 16. Which as the function name suggests this is max value.
So how could I know if my application is running al those 16 threads or 4 threads ? Maybe 2 cores ?
VaishnaviV_Intel
Thanks for posting on Intel communities.
You can use the Hotspots Views in Intel® VTune™ Profiler tool to gather information about the number of cores, number of threads, and determine whether your application is utilizing a single core or multiple cores.
Please refer to the below link for further details,
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2023-0/hotspots-view.html
If you still face any issues, please let us know.
Thanks & Regards,
Vankudothu Vaishnavi.
VaishnaviV_Intel
We have not heard back from you.
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks & Regards,
VaishnaviV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
