887 Discussions
Optimizing Performance and Memory Usage in ImGui-based Applications: Strategies and Limitations
CarolJenkins
When using ImGui, developers may encounter various compilation issues that can cause frustration and delay in the development process. These issues can range from missing headers or undefined symbols to compatibility problems with different compilers or platforms. To overcome these challenges, developers need to have a good understanding of the library's architecture, APIs, and dependencies, as well as the tools and techniques available to troubleshoot and optimize their code.
Specifically, what are some common causes of compilation problems in ImGui, and how can developers diagnose and fix them? Are there any best practices or guidelines that they should follow to ensure smooth integration of the library with their existing codebase, and to avoid conflicts or errors during the build process?
In addition to addressing compilation issues, developers also need to consider the performance and memory usage of their ImGui-based applications. How can they optimize the rendering speed and memory footprint of their UIs, while maintaining responsiveness and visual fidelity? What are some common pitfalls or limitations to keep in mind when using ImGui, such as the trade-offs between simplicity and flexibility, or the impact of custom widgets or styles on performance?
Finally, how can developers stay up-to-date with the latest features and updates in the ImGui community, and contribute to its development and improvement! Are there any resources, forums, or communities that they can join to learn from other users, share their experiences, and collaborate on new ideas and projects
VarshaS_Intel
Could you please let us know if you have any issues with Intel oneAPI Products and Software? If yes, then could you please let us know the OS details, hardware, and Intel oneAPI version you are using?
And, could you please provide us with the sample reproducer code(or build any application with Intel compilers) along with the steps to reproduce the issue at our end? Also, please provide us with the error you are facing.
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need additional information, please start a new question.
Thanks & Regards,
Varsha
