Re: Regarding dpc++ usage
Christoph9
New Contributor II
Hey,
Regarding 1: You are probably trying to compile on the login-nodes. Try for example a Xeon-Node with
qsub -I -l nodes=1:xeon:ppn=2
Here is gcc 9 loaded per default. On these (and other nodes, but not the login nodes), you should be able to use the module command. This is documented here: https://devcloud.intel.com/oneapi/documentation/modules/ (In your case you can load another gcc-module, e.g. 10.3).
Christoph
