Resulting executable and CPU/GPUs
eldiener
If I create a resulting executable with the Data Parallel C++ compiler is that executable limited in any way when being run on non-Intel CPUs or GPUs ?
RahulV_intel
DPC++ compilation can be performed in two ways:
  • JIT (Just in Time) compilation (Online compilation)
  • AOT (Ahead of Time) compilation (Offline compilation)
JIT compilation loads a generic SPIRV image into the executable. The machine code will be generated "on the fly" for the device that is being targeted.
AOT compilation loads a device-specific image into the executable. The machine code will be generated during the compilation phase ("Ahead of time") for the target device.
In short, the JIT-compiled executables should be portable (provided you have installed the same oneAPI version across both machines).
More information here:
https://software.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/programming-interface/cpu-flow.html
Currently, oneAPI doesn't support non-Intel accelerators. You can check the hardware requirements here:
https://software.intel.com/content/www/us/en/develop/articles/intel-oneapi-base-toolkit-system-requirements.html
However, the open Github release of DPC++ has limited support for non-Intel accelerators. https://github.com/intel/llvm/blob/sycl/sycl/doc/GetStartedGuide.md
Rahul
RahulV_intel
Any updates on this? If the solution provided helped, could you please let me know if I can close this thread from my end?
Rahul
RahulV_intel
I have not heard back from you, so I will go ahead and close this thread from my end. Feel free to post a new query if your issue persists.
Rahul
