SYCL target is invalid nvptx64-cuda
parody9
I am following this guide(https://intel.github.io/llvm-docs/GetStartedGuide.html) to learn DPC++ , I got an error like this
command :
clang++ -fsycl -fsycl-targets=nvptx64-nvidia-cuda-sycldevice nvidia-test-app.cpp
error:
clang++: error: SYCL target is invalid: 'nvptx64-nvidia-cuda-sycldevice'
How can I solve this error?( I did configure.py option --cuda and compile.py executed well.)
My clinfo - l
Platform #0: Intel(R) FPGA Emulation Platform for OpenCL(TM)
`-- Device #0: Intel(R) FPGA Emulation Device
Platform #1: Intel(R) OpenCL
`-- Device #0: AMD Ryzen 7 3700X 8-Core Processor
Platform #2: NVIDIA CUDA
`-- Device #0: GeForce RTX 2080 SUPER
GouthamK_Intel
Thanks for reaching out to us!
This forum is intended to support Intel oneAPI Products only. As we can see that you are using an open-source version of oneAPI for Nvidia devices support, we request you to raise an issue in GitHub for faster response: https://github.com/intel/llvm/issues
If you intended to use Intel oneAPI Products,  one place to download a free community version is the Intel oneAPI Base Toolkit and follow the installation guide to install the toolkit and required driver.
After installing the Intel oneAPI Base toolkit, you can refer to the below Get-Started guide for Linux.
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-linux/top.html
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Have a Good day!
Thanks & Regards
Goutham
parody9
Sorry i'm late to check your reply.
I appreciate for your answer.
GouthamK_Intel
Could you please let us know if your issue is resolved or not?
If your issue is resolved, let us know if we can close this thread.
Thanks & Regards
Goutham
GouthamK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
dpcpp_llvm
Sir, I am also facing same issue. And i have been trying this but no solution. Please help me.
1. My GPU is: NVIDIA GeFOrce GTX 1050 Ti
2. I have installed cuda and cuda Toolkit.
3. I have gone through https://intel.github.io/llvm-docs/GetStartedGuide.html#prerequisites link and trying to build dpc++ program with support for NVIDIA CUDA.
4. I have done compile.py and configure.py successfully. And getting error when trying to compile dpc++ using
5. command:  DPCPP_HOME/llvm/build/bin/clang++ -std=c++17 -O3 -fsycl -fsycl-targets=nvptx64-nvidia-cuda --cuda-path=/usr/local/cuda-11.7/targets/x86_64-linux/ add1DBuf.cpp -o a.out
after executing the command the error is:
clang-14: error: unkown argument: '-fsycl-targets=nvptx64-nvidia-cuda'
please help me to build
