891 Discussions
Simple example to Define function than call it from parallel_for kernal
pril
Hi
Thanks for DPC++ It's great,  Is there  a simple example for  :
Creating a simple  void function like  this and calling it from the  parallel_for kernal ?
#include <CL/sycl.hpp>
#include <iostream>
using namespace sycl;
Void Mycustomfunction( int avariable ){
  int myoutput=avariable+2;
  return myoutput;
int main(){
int N =5;
queue q ;
int *data = malloc_shared<int>(N, q);
for(int i = 0; N < 5; i++) {
data[i]=i;
q.parallel_for(range<1>(N), [=] (id<1> i){
data[i]=Mycustomfunction(i);
}).wait();
GouthamK_Intel
Hi Prilvesh Krishna,
Thank you for the kind feedback, we are glad to know that you liked DPC++.
You can achieve the above scenario in two ways.
1) Use accessor datatype instead of int* variable inside the function definition /declaration.
Example:
void Mycustomfunction(cl::sycl::accessor<int, 1, cl::sycl::access::mode::write> p, int x);
2) Typecast accessor address (aa) to (int *) inside the kernel and use int * in function definition/ declaration.
Example:
void Mycustomfunction(int *p, int x);
Also, I'm attaching the complete working code sample(with both methods) below as per your requirement.
#include<iostream>
#include<CL/sycl.hpp>
using namespace std;
//void Mycustomfunction(int *p, int x); For Method 2 uncomment this
int main()
   const int N=5;
    int a[N];
    for(int i=0;i<N;i++)
        a[i]=i;
    cpu_selector device_selector;
    queue q(device_selector);
        buffer<int ,1> a_buff(a,range<1> (N));
        q.submit([&](handler &h)
            auto aa=a_buff.get_access<access::mode::write>(h);
            h.parallel_for(range<1>{N},[=](id<1> item)
                int index=item;
                Mycustomfunction(aa,index);
                 //Mycustomfunction((int *)&aa[0], index); For Method 2 uncomment this
        cout<<a[i]<<"\t";
    cout<<"\n"<<std::endl;
void Mycustomfunction(cl::sycl::accessor<int, 1, cl::sycl::access::mode::write> p, int x){
        p[x]=x+2;
/* For Method 2 uncomment this
void Mycustomfunction(int *p,int x)
    p[x]=x+2;
Please feel free to reach out to us if you are facing any further issues in running this code.
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Example:
Example:
#include<iostream>
int main()
   const int N=5;
    int a[N];
        a[i]=i;
                int index=item;
        cout<<a[i]<<"\t";
        p[x]=x+2;
    p[x]=x+2;
Have a Good day!
Thanks & Regards
Goutham
pril
Thank you   this example  works great .
GouthamK_Intel
Thanks for the confirmation!
Glad to know that your issue is resolved.
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
