Sycl 2020 on devcloud?
Victor_E_1
How much of SYCL 2020 is availabe on the devcloud?
reduct1d.cxx:45:38: error: no member named 'reducer' in namespace 'cl::sycl'
        auto scalar_accessor = sycl::reducer
AbhishekD_Intel
If you want more details regarding the SYCL specification and DPC++, then please follow the below link it will give you complete details.
https://spec.oneapi.com/versions/latest/elements/dpcpp/source/index.html#extensions-table
From the error log, it's hard to come up with a conclusion regarding your issue, so if you have any issue regarding the reducer class which you are trying to use or reduction function please send us a small reproducer of your code so that we will get more insight into your issue.
Warm Regards,
Abhishek
Victor_E_1
Thanks for that table. That is useful. Here is my code and error message:
dpcpp -c reductscalar.cxx  -std=c++17 -O2 -g
reductscalar.cxx:42:11: error: no member named 'reduction' in namespace 'cl::sycl'
    sycl::reduction( sum_array, static_cast<float>(0.), std::plus<float>() );
1 error generated.
#include <CL/sycl.hpp>
#include <iostream>
#include <vector>
using std::vector;
#include <cstdio>
using namespace cl;
int main() {
  sycl::cpu_selector selector;
  sycl::queue myqueue(selector);
  auto ctx = myqueue.get_context();
  auto dev = myqueue.get_device();
  int array_size; std::cin >> array_size;
  float *shared_array = (float*) malloc_shared( array_size*sizeof(float),dev,ctx );
  float *sum_array = (float*) malloc_shared( sizeof(float),dev,ctx );
  float check_sum = 0.;
  for (int i=0; i<array_size; i++) {
    shared_array[i] = static_cast<float>(i);
    check_sum += shared_array[i];
  sycl::range<1> array_range{static_cast<size_t>(array_size)};
  //codesnippet syclsumreduct
  auto reduce_to_sum =
  myqueue.parallel_for// parallel_for<reduction_kernel<T,BinaryOp,__LINE__>>
    ( array_range,    // sycl::range<1>(input_size),
      reduce_to_sum,  // sycl::reduction(output, identity, op),
      [=] (sycl::id<1> idx, auto& reducer) { // type of reducer is impl-dependent, so use auto
      reducer.combine(shared_array[idx[0]]); //(input[idx[0]]);
      //reducer += shared_array[idx[0]]; // see line 216: add_reducer += input0[idx[0]];
    } ).wait();
  //codesnippet end
  printf("Sum= %e, s/b=%e\n",sum_array[0],check_sum);
  return 0;
AbhishekD_Intel
Thanks for the code snippet. We can see that you are trying to access reduction from sycl namespace, but the reduction functionality is present in a different namespace.
As you are trying to run your code on the Devcloud the SYCL_COMPILER_VERSION is greater than 20200827, so try using sycl::ONEAPI::reduction(....), this will not give the error on reduction function.
There is one more issue with your code, you are just using range with index with a reduction, but the reduction should be used with nd_range and nd_item in the data-parallel kernel.
You can follow the below syntax for reference.
using namespace sycl;
handler.parallel_for(
nd_range<1>{global_range, local_range},
ONEAPI::reduction(sum, plus<>()),
[=](nd_item<1> it, auto& sum) {
int i = it.get_global_id(0);
sum += data[i];
For more details please refer to the below OneAPI Samples (GSimulation.cpp)
https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2B/N-BodyMethods/Nbody
Hope the provided details will solve your issue.
Warm Regards,
Abhishek
AbhishekD_Intel
Please give us an update on the provided details and do let us know if it had solved your issue.
Warm Regards,
Abhishek
Victor_E_1
Abhishek,
the Sycl 2020 standard just came out, so I'm reluctant to use solutions that are based on Intel-only namespaces.
What are the plans for implementing the 2020 standard?
Victor.
AbhishekD_Intel
Hi Victor,
I will forward your question to the subject matter expert for more details regarding the implementation of the latest SYCL standard.
Please expect a reply in this same thread.
Warm Regards,
Abhishek
Varsha_M_Intel
some of the SYCL2020 features are already in DPC++ Compiler initial release and we will continue to add support for more in future releases. A comprehensive list will be released soon.
Varsha_M_Intel
