866 Discussions
Unable to compile sample code in VS2019 using Intel C++ 2023 compiler
TryerGit
I am attempting to compile and run the sample program provided at https://oneapi-src.github.io/DPCPP_Reference/model/sample-program.html
I encounter multiple issues with this code.
Firstly, the line:
#include <CL/sycl.hpp>
gives a compile error that the header file is not known. It had to be changed to:
#include <sycl/sycl.hpp>
Subsequently, attempting to compile the code results in multiple errors. A common error seems to be in "accessor.hpp" file:
#include <CL/__spirv/spirv_types.hpp>
The reported error is:
Error 'CL/__spirv/spirv_types.hpp' file not found with <angled> include; use "quotes" instead windows C:\Program Files (x86)\Intel\oneAPI\compiler\2023.0.0\windows\include\sycl\accessor.hpp(11,10): 1
Is there a way to fix this compile/build error? Please let me know if any additional information is needed to get the code up and running.
Thank you.
TryerGit
I added C:\Program Files (x86)\Intel\oneAPI\compiler\2023.0.0\windows\include\sycl to "Additional Include directories" and the above problems go away. However, now, the following error is obtained:
Error static assertion failed due to requirement '!std::is_same<sycl::detail::auto_name, sycl::detail::auto_name>::value': No kernel name provided without -fsycl-unnamed-lambda enabled! windows C:\Program Files (x86)\Intel\oneAPI\compiler\2023.0.0\windows\include\sycl\kernel.hpp(44,3): 1
Could you please point me to a reference where a sample compilation/build example is provided?
Thank you.
TryerGit
I was able to solve the problem. It was needed of me to set /fsycl in C/C++ -> DPC++ tab of Visual Studio project properties.
VarshaS_Intel
Glad to know that your issue is resolved.
Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Varsha
