881 Discussions
Unexpected runtime issue when migrating from Intel C++ Compiler 2025.0.1.28 to 2025.3.0.326
Nilesh_Shinde
I am working on an application that was previously compiled with Intel C++ Compiler 2025.0.1.28. The application includes the following function, which is intended to return 1 if the input string is empty and 0 otherwise. With version 2025.0.1.28, the function behaved as expected.
    int ParserCheckZeroLengthString(char* pStr)
        // check if this is a zero-length string
        if (NULL== pStr || pStr[0]=='\0')
                return 1;
        return 0;
After upgrading to Intel C++ Compiler 2025.3.0.326, the build completes successfully, but at runtime the function incorrectly returns 0 instead of 1 when the string is empty.
We are suspecting this issue may be related to compiler optimisations.
To address this, we attempted to disable or reduce optimisation using the following CMake flags, but they had no effect: Function continued to return 0 for empty parameter string.
////Disable optimisation
-DCMAKE_CXX_FLAGS_RELEASE="/Od /DNDEBUG"
-DCMAKE_C_FLAGS_RELEASE="/Od  /DNDEBUG"
and
////Reduce optimisation level
-DCMAKE_CXX_FLAGS_RELEASE="/O2 /Ob2 /DNDEBUG"
-DCMAKE_C_FLAGS_RELEASE="/O2  /Ob2/DNDEBUG"
Question:
How can we compile the existing code base with Intel C++ Compiler 2025.3.0.326 while preserving the same runtime behaviour as with version 2025.0.1.28?
Nilesh_Shinde
Adding printf("returning 1"); just before 'return 1;' statement in ParserCheckZeroLengthString function, code starts behaving correctly again. How to diagnose or fix this issue.?
