Using oneAPI and NVIDIA GPU on Windows 10
gstoilov
Hi, everybody,
I am trying to port a CUDA program to oneAPI.
The example “tbb-async-sycl” compiles and works fine, but
I mention that sycl::default_selector always selects CPU.
I changed the sycl::default_selector with sycl::gpu_selector, but
The program crashes at the row:
sycl::queue q(sycl::gpu_selector{}, dpc_common::exception_handler);
For the test, I added two rows at the beginning of the main function:
sycl::gpu_selector device_selector;
sycl::queue q(device_selector);
and again the exception is raised.
Unhandled exception at 0x00007FFEB3E24B89 in tbb-async-sycl.exe: Microsoft C++ exception: cl::sycl::runtime_error at memory location 0x000000E59A71F0D8.
Is it possible to use oneAPI with Windows 10 21H1 and NVIDIA RTX2070 as a GPU device for calculations?
Thank you in advance
SantoshY_Intel
Since you are using an accelerator other than Intel, Please use an open-source version of oneAPI which can be found at (https://intel.github.io/llvm-docs/GetStartedGuide.html).
We can see that you are having a valid support license. If you still face any issue, then please raise a support ticket at (https://supporttickets.intel.com/servicecenter?lang=en-US)
Please let us know if there is anything else that we can help you with? If not, let us know whether to close this thread.
Thanks & Regards,
Santosh
SantoshY_Intel
Could you please provide the information i.e from where did you install oneAPI(please provide the link of the website you referred to) and the version of oneAPI installed?
Thanks & regards,
Santosh
gstoilov
Thank you for asking me.
I have valid subscription for  Intel® oneAPI Base & HPC Toolkit (Single-Node) until
03/16/2023.
The installed components are from the files :
w_BaseKit_p_2021.2.0.2871_offline.exe
w_HPCKit_p_2021.2.0.2901_offline.exe
w_dpcpp-cpp-compiler_p_2021.2.1.3150_offline.exe
from the links below.
https://software.intel.com/content/www/us/en/develop/tools/oneapi/all-toolkits.html#base-kit
https://registrationcenter.intel.com/en/products/download/3994/
https://registrationcenter.intel.com/en/products/download/3997/
https://software.intel.com/content/www/us/en/develop/articles/intel-c-compiler-classic-2021-2-1-release.html
best regards
SantoshY_Intel
Thanks & Regards,
Santosh
SantoshY_Intel
Thanks for accepting as a solution.
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards,
Santosh
