873 Discussions
Wrong optimization in icx when using arch-consistency
Frank_R_1
Hi
We found a problem in Intel oneAPI 2025.3.1 which was not present in 2024.2.1
Please have a look at:
2024.2.1 (here everything is bit identical)
https://godbolt.org/z/3E6YerxWW
2025.3.1 (output for Re = 1.0000e+07 is different)
https://godbolt.org/z/67rjM1jWr
It boils down to usage of
__bwr_log@PLT vs  log@PLT
 left debug, right release
The problem is the same on both platforms Windows and Linux.
We heavily rely on bit identical results between relase and debug builds, which was given over the last years. (On an older parallel studio version I reported a similar bug which was then fixed later on)
Best regards
Frank
Frank_R_1
FYI:
We found out that with 2025.1.0 the problem emerges, before it was ok. You can verify this also with the godbolt links above.
Frank_R_1
FYI:
When using -fp-model=strict instead of -fp-model=precise it delivers bit identical results. We didn't find information about it in the release notes about that change.
Best regards
Frank
Sravani_K_Intel
HI @Frank_R_1 , I just tested this with our latest development branch compiler and can no longer reproduce the issue. Please retest your code when 2026.0 Compiler is available in a few weeks.
