char array sample
bo__john
I wants to got sample code of char type array in the buffer matrix and with multiple loops with devcloud dpc++ compiler.
like
  struct s
        int id;
        char a[50];
struct s dt_v1[1188];
     strcpy(dt_v1[0].a, "102755703");
strcpy(dt_v1[1].a, "ab10");
strcpy(dt_v1[2].a, "cd10");
strcpy(dt_v1[3].a, "EF13");
strcpy(dt_v1[4].a, "5");
strcpy(dt_v1[5].a, "##184");
strcpy(dt_v1[6].a, "@@1");
strcpy(dt_v1[7].a, "&&13");
strcpy(dt_v1[8].a, "%%14");
strcpy(dt_v1[9].a, "!!1");
and how to transfer the string to int or float, like
dint_1 = atoi(dt_r1[dv_i1].a);
how to connect with parallel loop and buffer array. complete code sample needs. thanks.
buffer<char, 1>
    h.parallel_for<class computeB>(range<1>{N}, [=](id<1> ID) {
      accB[ID] = accA[ID] + 1;
so I searching a lots of SYCL documents, but platform devcloud oneAPI dpc++ not workable, and
how to write the full example code for that kinds operation,
https://github.com/intel/HPCKit-code-samples
this address with a lots of complex sample for array type with int and float, not multi matrix char array sample.
Thanks so lot.
GouthamK_Intel
We are working on it and will get back to you.
-Goutham
GouthamK_Intel
Hi John,
Please find the below sample code for creating buffers and accessors for struct.
#include <CL/sycl.hpp>
#include <iostream>
using namespace std;
using namespace cl::sycl;
 struct myStruct
        int id=1234;
        char a[50];
int main(){
    struct myStruct dt_v1[10];
    int test1=atoi(dt_v1[4].a);
    std::cout<<"Converting char[] to int "<<test1<<std::endl;
// ---------SYCL SCOPE STARTS------------
        default_selector device_selector;
        queue device_queue(device_selector);
        cout<<device_queue.get_device().get_info<info::device::name>()<<std::endl;  //print name of the device it is running on.
        buffer<struct myStruct,1> a(dt_v1,range<1>{10});
        device_queue.submit([&](handler &cgh){
            auto Accessor =a.get_access<access::mode::write>(cgh);
            cgh.parallel_for<class StructClass>(range<1>{10},[=](id<1> index){
             struct myStruct* myAcc=(struct myStruct*)(&Accessor[index]);
                // your code logic starts from here..
                // to access array "a" use this
                     //char* myArray=myAcc->a;
                // To access int "id" use this
                    //int myId=myAcc->id;
    return 0;
Feel free to reach out to us, in case you have any more queries.
Goutham
bo__john
Thank you for your quick response, and I try to this code with information, it is workable, but I didn't find the way,
how to do  individual  with function, and global declearation of struct. but I put it in main() function is runnable.
#include <iostream>
 struct myStruct
        int id=1234;
        char a[50];
struct myStruct dt_v1[1650];
int main(){
     abc();
// or void
int abc()
    strcpy(dt_v1[1].a, "102738922");
strcpy(dt_v1[2].a, "2019");
strcpy(dt_v1[3].a, "10");
strcpy(dt_v1[4].a, "25");
strcpy(dt_v1[5].a, "3U8093");
strcpy(dt_v1[6].a, "ZUUU");
strcpy(dt_v1[7].a, "WSSS");
strcpy(dt_v1[8].a, "2019");
strcpy(dt_v1[9].a, "10");
strcpy(dt_v1[10].a, "25");
strcpy(dt_v1[11].a, "13");
strcpy(dt_v1[12].a, "45");
strcpy(dt_v1[13].a, "0");
strcpy(dt_v1[14].a, "2019");
strcpy(dt_v1[15].a, "10");
strcpy(dt_v1[16].a, "25");
strcpy(dt_v1[17].a, "18");
strcpy(dt_v1[18].a, "40");
strcpy(dt_v1[19].a, "0");
strcpy(dt_v1[20].a, "I");
strcpy(dt_v1[21].a, "ac_1");
strcpy(dt_v1[22].a, "TYPE_C");
strcpy(dt_v1[23].a, "184");
strcpy(dt_v1[24].a, "43");
strcpy(dt_v1[25].a, "1");
int abc2()
    strcpy(dt_v2[1].a, "102738922");
strcpy(dt_v2[2].a, "2019");
strcpy(dt_v2[3].a, "10");
strcpy(dt_v2[4].a, "25");
strcpy(dt_v2[5].a, "3U8093");
strcpy(dt_v2[6].a, "ZUUU");
strcpy(dt_v2[7].a, "WSSS");
strcpy(dt_v2[8].a, "2019");
strcpy(dt_v2[9].a, "10");
strcpy(dt_v2[10].a, "25");
strcpy(dt_v2[11].a, "13");
strcpy(dt_v2[12].a, "45");
strcpy(dt_v2[13].a, "0");
strcpy(dt_v2[14].a, "2019");
strcpy(dt_v2[15].a, "10");
strcpy(dt_v2[16].a, "25");
strcpy(dt_v2[17].a, "18");
strcpy(dt_v2[18].a, "40");
strcpy(dt_v2[19].a, "0");
strcpy(dt_v2[20].a, "I");
strcpy(dt_v2[21].a, "ac_1");
strcpy(dt_v2[22].a, "TYPE_C");
strcpy(dt_v2[23].a, "184");
strcpy(dt_v2[24].a, "43");
strcpy(dt_v2[25].a, "1");
At second, possible running the parallel function like that ?
 please help give the dpcpp_parallel fuction like below, if i have more initial data array,
struct myStruct dt_v2[1650];
struct myStruct dt_v3[1650];
if all the function in main, so big volume code, the structure is hard find whats the function name.
void dpcpp_parallel(float *a,float *v,float *d)
    try{
        // Setting up a queue to default DPC++ device selected by runtime
        queue device_queue;
        // Setup buffers for input and output vectors
        buffer<float, 1> bufv1(a,range<1>(N));
        buffer<float, 1> bufv2(v, range<1>(N));
        buffer<float, 1> bufv3(d, range<1>(N));
        auto start_time = std::chrono::high_resolution_clock::now();
        std::cout<<"Target Device: "<<device_queue.get_device().get_info<info::device::name>()<<"\n";
        //Submit Command group function object to the queue
        device_queue.submit([&](handler& cgh) {
        auto acc_vect1 = bufv1.get_access<access::mode::read>(cgh);
        auto acc_vect2 = bufv2.get_access<access::mode::read>(cgh);
        auto acc_vect3 = bufv3.get_access<access::mode::write>(cgh);
        cgh.parallel_for<class CompIntegral>(range<1>(N), [=](id<1> i) {
            float dx = (float) ((acc_vect1 - acc_vect2)/d_x);
            float area_int = 0;
            for(int j =0; j< d_x; j++)
                float xC = acc_vect1 + dx * j;
                float yC = function_x(xC);
                area_int = xC * yC;
                area_int += area_int;
            acc_vect3 = area_int;
        device_queue.wait();
        auto current_time = std::chrono::high_resolution_clock::now();
        std::cout << "Parallel: Program has been running for " << std::chrono::duration<double>(current_time - start_time).count() << " seconds" << std::endl;
     catch (cl::sycl::exception e) {
         std::cout << "SYCL exception caught: " << e.what() << std::endl;
int main(){
    float lBound,uBound,i_area,d;
    //Initialize the lower bound and upper bound of the x axis arrays. Below we are initializing such that upper bound is always greater than the lower bound.
    for (int i=0;i<N;i++)
        lBound = i+40 + 10;
        uBound = (i+1)*40 + 70;
        i_area = 0;
        d = 0;
    //Call the dpcpp_parallel function with lBound and uBound as inputs and i_area array as the output
    dpcpp_parallel(lBound,uBound,i_area);
GouthamK_Intel
Hi John,
Please find the below sample code as per your requirements.
#include <iostream>
 struct myStruct
        int id=1234;
        char a[50];
struct myStruct dt_v2[10];
void abc1(){
void abc2(){
    strcpy(dt_v2[0].a, "102755703");
    strcpy(dt_v2[1].a, "ab10");
    strcpy(dt_v2[2].a, "cd10");
    strcpy(dt_v2[3].a, "EF13");
    strcpy(dt_v2[4].a, "5");
    strcpy(dt_v2[5].a, "##184");
    strcpy(dt_v2[6].a, "@@1");
    strcpy(dt_v2[7].a, "&&13");
    strcpy(dt_v2[8].a, "%%14");
    strcpy(dt_v2[9].a, "!!1");
void dpcpp_parallel(){
        buffer<struct myStruct,1> buff_dt_v1(dt_v1,range<1>{10});
        buffer<struct myStruct,1> buff_dt_v2(dt_v2,range<1>{10});
            auto acc_dt_v1 =buff_dt_v1.get_access<access::mode::write>(cgh);
            auto acc_dt_v2 =buff_dt_v2.get_access<access::mode::write>(cgh);
             struct myStruct* myAcc1=(struct myStruct*)(&acc_dt_v1[index]);
             struct myStruct* myAcc2=(struct myStruct*)(&acc_dt_v2[index]);
            //**************your code logic starts from here**************************
                     char* myArray1=myAcc1->a;
                     char* myArray2=myAcc2->a;
                    int myId=myAcc->id;
int main(){
    abc1(); // Initialisation for dt_v1[]
    abc2(); // Initialisation for dt_v2[]
    dpcpp_parallel();
    return 0;
Hope this helps. Feel free to reach out to us, in case you have any more queries.
Goutham
bo__john
Hi, Goutham,
   I am copy this code to platform" ssh devcloud" using bash, it is not working. Please see the information below:
Makefile
DPCPP_CXX = dpcpp
DPCPP_CXXFLAGS = -o
DPCPP_LDFLAGS =
DPCPP_EXE_NAME = t27
DPCPP_SOURCES = src/t27.cpp
all:
    $(DPCPP_CXX) $(DPCPP_CXXFLAGS) $(DPCPP_EXE_NAME) $(DPCPP_SOURCES) $(DPCPP_LDFLAGS)
build_dpcpp:
run:
    ./$(DPCPP_EXE_NAME)
instruction
qsub -l nodes=2:gpu:ppn=2 -d . build.sh
    qsub -l nodes=2:gpu:ppn=2 -d . run.sh
result
u35272@login-1:~/exc/dpc1/dpc_4$ cat *o*493
#      Date:           Sat Jan 25 13:01:30 PST 2020
#    Job ID:           473493.v-qsvr-1.aidevcloud
#      User:           u35272
# Resources:           neednodes=2:gpu:ppn=2,nodes=2:gpu:ppn=2,walltime=06:00:00
dpcpp -o t27 src/t27.cpp
Makefile:23: recipe for target 'build_dpcpp' failed
and  code I writing also not working on this platform..
u35272@login-1:~/exc/dpc1/dpc_4$ cat src/t26.cpp
#include <iostream>
 struct myStruct
        int id=1234;
        char a[50];
int main(){
     abc();
        buffer<struct myStruct,1> a(dt_v1,range<1>{1650});
            cgh.parallel_for<class StructClass>(range<1>{1650},[=](id<1> index){
      for (int i = 1; i < 1651; i++) {
    std::cout << dt_v1.a <<std::endl;
    return 0;
int abc(){
if I copy all function in main() function, it is workable.
u35272@login-1:~/exc/dpc1/dpc_4$ cat src/t25.cpp
#include <iostream>
 struct myStruct
        int id=1234;
        char a[50];
int main(){
strcpy(dt_v1[1649].a, "39");
strcpy(dt_v1[1650].a, "1");
    return 0;
GouthamK_Intel
Hi John,
Can you please try running the below code again. I verified in devcloud and it is working fine.
If still, your problem persists. please attach your source code, Makefile, build.sh, run.sh, .o**** file and .e***** files. So that we can investigate more about your issue.
#include <iostream>
 struct myStruct
        int id=1234;
        char a[50];
void abc1(){
void abc2(){
                    int myId=myAcc1->id;
int main(){
    dpcpp_parallel();
    return 0;
Goutham
bo__john
Hi, Goutham,
  The last code is ok, but the data function must at the up side of the main function.
  I have new question, I wants copy the first array to second array as regular period, like that:
struct myStruct dt_v13[3];
struct myStruct dt_v14[3];
struct myStruct dt_v15[3];
void abc1(){
    strcpy(dt_v1[3].a, "13");
    strcpy(dt_v1[4].a, "aa5");
    strcpy(dt_v1[5].a, "aa184");
    strcpy(dt_v1[6].a, "1");
int i, j1, j2, j3, k;
// I put this loop in main() but compile ok,  run failed for a large number,
//it only running more than 100, but my dat is more than 1000++
for(i=0; i<10; i++)
	j1 =i*3;
    j2 = j1+1;
    j3 = j1+2;
    k=j1/3;
strcpy(dt_v13.a, dt_v1[j1].a);
strcpy(dt_v14.a, dt_v1[j2].a);
strcpy(dt_v15.a, dt_v1[j3].a);
// this loop in main()
 for (int i = 0; i < 3; i++) {
    std::cout << dt_v3.a <<std::endl;
my last code and result
int main(){
     int j, test1;
    abc(); // Initialisation for dt_v1[]
    dpcpp_parallel();
		  j=i*25;
    return 0;
u35272@login-2:~/exc/dpc1/dpc_5$ cat *o*917
#      Date:           Wed Jan 29 12:59:16 PST 2020
#    Job ID:           477917.v-qsvr-1.aidevcloud
#      User:           u35272
./t29
Intel(R) Gen9 HD Graphics NEO
102809408
102755703
102772414
102756988
102782321
102755748
102743577
102824987
102750121
102784113
102752389
102834161
102818434
102829292
102813096
102744544
102838772
102847134
102738468
102740481
102844083
102752193
102757704
102822715
102815659
102807175
102801481
102760240
102744845
102746524
102750141
102812579
102813198
102817848
102775056
102826594
102738494
102753935
102761366
102745783
102797165
102749800
102754511
102843550
102749845
102805684
102739925
102822741
102825670
102834045
102771447
102749888
102781802
102834752
102829958
102990200
102782250
102756310
102831321
102827544
102820133
102754463
102829326
102752257
102738743
Makefile:25: recipe for target 'run_dpcpp' failed
# End of output for job 477917.v-qsvr-1.aidevcloud
# Date: Wed Jan 29 12:59:19 PST 2020
then
At first copy dt_v1[0].a and dt_v1[5].a to new array dt_v3[0].a and dt_v3[1].a, then atoi to integer,
then operation to a integer array,
may be arithmetic operation , like sum to new array C[index] = sum, and where can do cout of those array.
please give a example like that:
        //Submitting command group to queue to compute matrix mulitiplication c=a*b
            // Read from a and b, write to c
            auto A = a.get_access<access::mode::read>(cgh);
            auto B = b.get_access<access::mode::read>(cgh);
            auto C = c.get_access<access::mode::write>(cgh);
            int WidthA = a.get_range()[1];
            //Executing kernel
            cgh.parallel_for<class MatrixMult>(range<2>{M, P}, [=](id<2> index){
	        //Get global position in Y direction
	        int row = index[0];
	        //Get global position in X direction
	        int col = index[1];
	        double sum = 0.0;
	        //Compute the result of one element in c
	        for (int i = 0; i < WidthA; i++) {
	            sum += A[row] * B[col];
	        C[index] = sum;
    }    //End of scope, so we wait for kernel producing result data to host memory c_back to complete
and if I do the parallel loop with difference length of different array, use the function like below:
// Matrix size constants
#define SIZE     1200     // Must be a multiple of 8.
#define M        SIZE/8
#define N        SIZE/4
#define P        SIZE/2
     // Submitting command group to queue to initialize matrix a
        device_queue.submit([&](handler &cgh) {
            // Getting write only access to the buffer on a device
            auto Accessor = a.get_access<access::mode::write>(cgh);
            // Executing kernel
            cgh.parallel_for<class FillBuffer_a>( range<2>{M, N}, [=](id<2> index) {
                // a is identity matrix
                Accessor[index] = 1.0;
        //Submitting command group to queue to initialize matrix b
            auto Accessor = b.get_access<access::mode::write>(cgh);
            //Executing kernel
            cgh.parallel_for<class FillBuffer_b>( range<2>{N, P}, [=](id<2> index){
	        // each column of b is the sequence 1,2,...,N
                Accessor[index] = index[0] + 1.;
Please give a complete code example.
Thank You!
John
GouthamK_Intel
Hi John,
Glad to hear that the solution provided helped and your issue is resolved.
Can you please raise a new thread for your new issue?
Please confirm whether we can close this thread.
Thanks, Have a good day!
Goutham
GouthamK_Intel
Hi John,
Could you please confirm whether we can close this thread.
Goutham
