compilation issues with oneDPL headers
alexstrelch
hello,
I tried to compile test codes from oneAPI-samples  using the new toolkit. Some of them failed with the following error message  :
In file included from /home/astrel/work/Crs/oneAPI-samples/DirectProgramming/DPC++/ParallelPatterns/histogram/src/main.cpp:9:
In file included from /opt/intel/oneapi/dpl/2021.7.2/linux/include/oneapi/dpl/execution:34:
In file included from /opt/intel/oneapi/dpl/2021.7.2/linux/include/oneapi/dpl/pstl/glue_algorithm_impl.h:23:
In file included from /opt/intel/oneapi/dpl/2021.7.2/linux/include/oneapi/dpl/pstl/utils.h:31:
/opt/intel/oneapi/dpl/2021.7.2/linux/include/oneapi/dpl/pstl/hetero/dpcpp/sycl_iterator.h:34:68: error: no type named 'buffer_allocator' in namespace 'sycl'; did you mean 'image_allocator'?
template <access_mode Mode, typename T, typename Allocator = sycl::buffer_allocator>
The errors seem to be due to onedpl headers.
Any idea to resolve the issue?
Thank you.
NoorjahanSk_Intel
We have tried to build the sample using below steps and we are able to get the expected results without any issues.
Steps we have followed on Ubuntu:
Please find the below screenshot for the result.
Please follow the above steps while building the code. If you still face the issue, please provide us with the below details.
  1. Steps you have followed to build the sample code.
  2. Os details
  3. Compiler version being used.
Thanks & Regards,
Noorjahan.
alexstrelch
Thank you, Noorjahan.
Here are the details:
1. Steps:
git clone https://github.com/oneapi-src/oneAPI-samples
module load cmake
source /opt/intel/oneapi/setvars.sh
cd ./oneAPI-samples/DirectProgramming/DPC++/ParallelPatterns/histogram
mkdir build & cd build
cmake ..
make VERBOSE=1
2. OS:
Linux {hostname} 5.15.0-50-generic #56~20.04.1-Ubuntu SMP Tue Sep 27 15:51:29 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
3. Compiler:
Intel(R) oneAPI DPC++/C++ Compiler 2023.0.0 (2023.0.0.20221201)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm
Configuration file: /opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/../bin/icpx.cfg
4. Error message (and there were a bunch of warnings):
/opt/intel/oneapi/compiler/2023.0.0/linux/bin/icpx -O3 -std=c++17 -fsycl -O3 -DNDEBUG -MD -MT CMakeFiles/histogram.dir/src/main.cpp.o -MF CMakeFiles/histogram.dir/src/main.cpp.o.d -o CMakeFiles/histogram.dir/src/main.cpp.o -c /home/astrel/work/Crs/Tmp/oneAPI-samples/DirectProgramming/DPC++/ParallelPatterns/histogram/src/main.cpp :
In file included from /home/astrel/work/Crs/Tmp/oneAPI-samples/DirectProgramming/DPC++/ParallelPatterns/histogram/src/main.cpp
In file included from /home/astrel/work/Crs/Tmp/oneAPI-samples/DirectProgramming/DPC++/ParallelPatterns/histogram/src/main.cpp:9:
image_allocator
Direct compiling of the source resulted in the same error.
Thank you,
NoorjahanSk_Intel
Thanks for providing the details.
From your error, we observed that you are using OneDPL 2021.7 version.
Could you please upgrade to the latest OneDPL version(2022.0.0) and try to build your code with the latest version?
We tried with OneDPL(2022.0.0) and did not see any issues at our end.
You can get the latest version by installing the entire OneAPI BaseTookit or the standalone version.
BaseToolkit:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
Standalone:
https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
alexstrelch
Hi Noorjahan,
I just re-installed the toolkit and could compile the code sample, thank you for the instructions. You can close the issue.
A.
NoorjahanSk_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread.
Thanks & Regards,
Noorjahan.
