- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
With O2 optimization, it produces wrong result whereas Intel 19.1 compiler produces correct result.
std::vector<SMDBL> dWdLambda(3,0.);
MATRIX2DZERO(d2Wd2Lambda, SMDBL, 3, 3);
for(INTL1 k=0; k<numMu_; k++){
SMDBL jInvAlpha = std::pow(jvalue,-alpha_[k]/3.);
SMDBL factor = jInvAlpha*mu_[k]/3.;
// factor *=
dWdLambda[0] += (factor/lambda[0])*(+2*std::pow(lambda[0],alpha_[k]) - std::pow(lambda[1],alpha_[k])
- std::pow(lambda[2],alpha_[k]));
dWdLambda[1] += (factor/lambda[1])*(-std::pow(lambda[0],alpha_[k]) + 2.*std::pow(lambda[1],alpha_[k])
dWdLambda[2] += (factor/lambda[2])*(-std::pow(lambda[0],alpha_[k]) - std::pow(lambda[1],alpha_[k])
+ 2.*std::pow(lambda[2],alpha_[k]));
if(elPtr!=NULL){
if(elPtr->getUserID()==-99999999){
// NOTE: This is to avoid a bug in intel dpc++ compiler bug in O2 optimization(release module)
// Compiler is optimizing too much causing dWdLambda to be infinite.
// (probably compilier is doing some optimization). To remove this, please test with
// release module and dpc++ comiler.
PRINT_DIAG(ASSEMBLY_DIAG,0,"dWdLambda",&dWdLambda[0],3);
SMDBL factor2 = alpha_[k]*factor/3.; // alpha_[k]*mu(J^-alpha/3)/9
d2Wd2Lambda[0][0] += (factor2/lambda2[0])*(
4.*std::pow(lambda[0],alpha_[k])+std::pow(lambda[1],alpha_[k])+std::pow(lambda[2],alpha_[k]))
- (factor/lambda2[0])*(+2*std::pow(lambda[0],alpha_[k]) - std::pow(lambda[1],alpha_[k])
d2Wd2Lambda[0][1] += (factor2/(lambda[0]*lambda[1]))*(
-2.*std::pow(lambda[0],alpha_[k]) - 2.*std::pow(lambda[1],alpha_[k]) + std::pow(lambda[2],alpha_[k]));
d2Wd2Lambda[0][2] += (factor2/(lambda[0]*lambda[2]))*(
-2.*std::pow(lambda[0],alpha_[k]) + std::pow(lambda[1],alpha_[k]) - 2*std::pow(lambda[2],alpha_[k]));
d2Wd2Lambda[1][1] += (factor2/lambda2[1])*(
std::pow(lambda[0],alpha_[k])+4.*std::pow(lambda[1],alpha_[k])+std::pow(lambda[2],alpha_[k]))
- (factor/lambda2[1])*(-std::pow(lambda[0],alpha_[k]) + 2.*std::pow(lambda[1],alpha_[k])
d2Wd2Lambda[1][2] += (factor2/(lambda[1]*lambda[2]))*(
+ std::pow(lambda[0],alpha_[k]) - 2.*std::pow(lambda[1],alpha_[k]) - 2*std::pow(lambda[2],alpha_[k]));
d2Wd2Lambda[2][2] += (factor2/lambda2[2])*(
std::pow(lambda[0],alpha_[k])+std::pow(lambda[1],alpha_[k])+4.*std::pow(lambda[2],alpha_[k]))
- (factor/lambda2[2])*(-std::pow(lambda[0],alpha_[k]) - std::pow(lambda[1],alpha_[k])
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Could you please provide the following information?
1)DPC++ version and OS you are using.
2)The complete sample reproducer code(The above provided code is not sufficient for analyzing your issue).
3)The compilation and execution command for reproducing this issue.
4)Screenshots for correct and incorrect results with respect to Intel compiler(19.1) and DPC++.
Thanks & Regards,
Hemanth.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We haven't heard back from you. Could you please provide the above requested details?
Thanks & Regards,
Hemanth.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Hemanth.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
