dpcpp ICE Trace/breakpoint trap
vzecca
cat dpcpperr7.c
//dpcpp ICE Trace/breakpoint trap
struct S { int c, *b, *e; };
void
foo ()
struct S a;
asm volatile ("" : "=rm" (a) : "0" (1));
dpcpp dpcpperr7.c
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: /opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang++ -cc1 -triple x86_64-unknown-linux-gnu -sycl-std=2020 -fsycl-unnamed-lambda -include /tmp/dpcpperr7-header-a01796.h -dependency-filter /tmp/dpcpperr7-header-a01796.h -fsycl-is-host -emit-obj --mrelax-relocations -disable-free -disable-llvm-verifier -discard-value-names -main-file-name dpcpperr7.c -mrelocation-model static -fveclib=SVML -mframe-pointer=none -menable-no-infs -menable-no-nans -menable-unsafe-fp-math -fno-signed-zeros -mreassociate -freciprocal-math -fdenormal-fp-math=preserve-sign,preserve-sign -ffp-contract=fast -fno-rounding-math -ffast-math -ffinite-math-only -mconstructor-aliases -munwind-tables -target-cpu x86-64 -mllvm -x86-enable-unaligned-vector-move=true -tune-cpu generic -debugger-tuning=gdb -fcoverage-compilation-dir=/home/vitti/f95/cc -resource-dir /opt/intel/oneapi/compiler/2021.3.0/linux/lib/clang/13.0.0 -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/bin/../include/sycl -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/bin/../include -I/opt/intel/oneapi/vpl/2021.4.0/include -I/opt/intel/oneapi/tbb/2021.3.0/env/../include -I/opt/intel/oneapi/mpi/2021.3.0//include -I/opt/intel/oneapi/mkl/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/ippcp/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/dpl/2021.4.0/linux/include -I/opt/intel/oneapi/dpcpp-ct/2021.3.0/include -I/opt/intel/oneapi/dnnl/2021.3.0/cpu_dpcpp_gpu_dpcpp/lib -I/opt/intel/oneapi/dev-utilities/2021.3.0/include -I/opt/intel/oneapi/dal/2021.3.0/include -I/opt/intel/oneapi/compiler/2021.3.0/linux/include -I/opt/intel/oneapi/ccl/2021.3.0/include/cpu_gpu_dpcpp -I/opt/intel/oneapi/vpl/2021.4.0/include -I/opt/intel/oneapi/tbb/2021.3.0/env/../include -I/opt/intel/oneapi/mpi/2021.3.0//include -I/opt/intel/oneapi/mkl/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/ippcp/2021.3.0/include -I/opt/intel/oneapi/ipp/2021.3.0/include -I/opt/intel/oneapi/dpl/2021.4.0/linux/include -I/opt/intel/oneapi/dpcpp-ct/2021.3.0/include -I/opt/intel/oneapi/dnnl/2021.3.0/cpu_dpcpp_gpu_dpcpp/lib -I/opt/intel/oneapi/dev-utilities/2021.3.0/include -I/opt/intel/oneapi/dal/2021.3.0/include -I/opt/intel/oneapi/compiler/2021.3.0/linux/include -I/opt/intel/oneapi/ccl/2021.3.0/include/cpu_gpu_dpcpp -cxx-isystem /opt/intel/oneapi/clck/2021.3.0/include -cxx-isystem /opt/intel/oneapi/clck/2021.3.0/include -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/bin/../compiler/include -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11 -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11/x86_64-redhat-linux -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11/backward -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11 -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11/x86_64-redhat-linux -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../include/c++/11/backward -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/lib/clang/13.0.0/include -internal-isystem /usr/local/include -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../x86_64-redhat-linux/include -internal-externc-isystem /include -internal-externc-isystem /usr/include -internal-isystem /opt/intel/oneapi/compiler/2021.3.0/linux/lib/clang/13.0.0/include -internal-isystem /usr/local/include -internal-isystem /usr/lib/gcc/x86_64-redhat-linux/11/../../../../x86_64-redhat-linux/include -internal-externc-isystem /include -internal-externc-isystem /usr/include -O2 -std=c++17 -fdeprecated-macro -fdebug-compilation-dir=/home/vitti/f95/cc -ferror-limit 19 -fheinous-gnu-extensions -fgnuc-version=4.2.1 -fcxx-exceptions -fexceptions -fcolor-diagnostics -vectorize-loops -vectorize-slp -D__GCC_HAVE_DWARF2_CFI_ASM=1 -fintel-compatibility -mllvm -disable-hir-generate-mkl-call -mllvm -intel-libirc-allowed -mllvm -loopopt=0 -mllvm -enable-lv -o /tmp/dpcpperr7-2a7aae.o -x c++ dpcpperr7.c
1. <eof> parser at end of file
2. Code generation
3. Running pass 'Function Pass Manager' on module 'dpcpperr7.c'.
4. Running pass 'X86 DAG->DAG Instruction Selection' on function ''
#0 0x0000562bda85468a llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+++0x438f68a)
#1 0x0000562bda854430 llvm::sys::RunSignalHandlers() (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+++0x438f430)
#2 0x0000562bda854914 SignalHandler(int) (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+++0x438f914)
#3 0x0000149d128f5a20 (/usr/lib64/libpthread.so.0+0x13a20)
#4 0x0000562bd92a9908 (/opt/intel/oneapi/compiler/2021.3.0/linux/bin/clang+++0x2de4908)
dpcpp: error: unable to execute command: Trace/breakpoint trap (core dumped)
dpcpp: error: clang frontend command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2021.3.0 (2021.3.0.20210619)
Target: x86_64-unknown-linux-gnu
Thread model: posix
NoorjahanSk_Intel
We are also able to reproduce the error at our end.
We are working on it internally and will get back to you soon.
Thanks & Regards
Noorjahan
PriyanshuK_Intel
Thank you for your patience.
The issue raised by you have been fixed in Intel oneAPI 2022.3
 Please download and let us know if this resolves your issue.
Priyanshu.
PriyanshuK_Intel
We assume that your issue is resolved. If you need additional information, please post a new question as this thread will no longer be monitored by Intel.
Priyanshu.
