835 Discussions
dpcpp ICE error in backend: cannot lower memory intrinsic in address space 256
vzecca
cat dpcpperr5.c
//dpcpp ICE error in backend: cannot lower memory intrinsic in address space 256
typedef __SIZE_TYPE__ size_t;
void
f1 (unsigned char __seg_gs *s, size_t n)
for (size_t i = 0; i < n; ++i) s[i] = 0;
dpcpp dpcpperr5.c
fatal error: error in backend: cannot lower memory intrinsic in address space 256
dpcpp: error: clang frontend command failed with exit code 70 (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2021.3.0 (2021.3.0.20210619)
Target: x86_64-unknown-linux-gnu
Thread model: posix
Khalik_K_Intel
As stated by Shivani, this issue was fixed in the released Intel oneAPI DPC++/C++ Compiler which is part of oneAPI 2022.1 Base Toolkit.
The toolkit can be downloaded here: https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
I have checked the reproducer from this forum thread with the released compiler and the code compiles successfully.
If you require additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
VidyalathaB_Intel
The issue raised by you is reproducible.
We are working on this issue internally. we will get back to you soon.
Vidya.
Khalik_K_Intel
Thank you for contacting Intel support.
We were able to reproduce issue on our end, as mentioned before.
We have now escalated this issue to a development team.
Once we have any update from the development team, I will inform you about it in this forum thread.
Have a nice day ahead!
Khalik.
ShivaniK_Intel
Thank you for your patience. The issue raised by you has been fixed in the latest intel oneAPI 2022.1 version release. So, could you please download and let us know if this resolves your issue.
Thanks & Regards
Shivani
Khalik_K_Intel
