failed to load igfxdcd into kernel
syk1
I am tring to install igfxdcd to debug dpcpp file according to this link
(https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-debugging-dpcpp-linux/top.html)
igfxdcd-1.8.0-Linux.deb is installed successfully, I can see compiled igfxdcd.ko under /lib/modules/5.4.0-77-generic/updates/dkms/
modinfo igfxdcd also shows something.
But modprobe igfxdcd failed with root user
modprobe: ERROR: could not insert 'igfxdcd': Operation not permitted
Kernel I am running is also same as kernel installed
root@station:/home/# uname -a
Linux 5.4.0-77-generic #86-Ubuntu SMP Thu Jun 17 02:35:03 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Do you have any idea on this and can provide some help?
My environment is ubuntu 20.04 on i7-10700K with a gen9 GPU
the oneAPI version is BaseKit_p_2021.3.0.3219
syk1
secure boot is turned off in this computer
ShivaniK_Intel
Could you please let us know whether the latest GPU drivers are installed on your system? If yes, please provide the version of GPU drivers.
If not, you can install the latest GPU drivers from the following link below.
https://dgpu-docs.intel.com/installation-guides/ubuntu/ubuntu-focal.html
Thanks & Regards
Shivani
syk1
Hi Shivani,
Yes, I have follow the instructions and install the latest driver on ubuntu.
I thought the reason should be my GPU is not included in official released igfxdcd 1.8.0
in the source code of igfxdcd, there is only 1 devide registered for commet lake (0x9BCA) in /usr/src/igfxdcd-1.8.0/skus.h
My device 0x9bc5 is not included.
output of lspci is:
00:02.0 VGA compatible controller: Intel Corporation Device 9bc5 (rev 05)
Yuankun
syk1
Hi Shivani,
Thanks for the update. It can still trigger the same error.
ShivaniK_Intel
We are working on it and will get back to you soon.
Thanks & Regards
Shivani
Sravani_K_Intel
Debugger team is looking into the issue, being tracked internally under DOQG-2431.
ShivaniK_Intel
Thank you for your patience. The issue raised by you has been fixed in the intel one API 2021.4 version. So, could you please download and let us know if this resolves your issue.
Thanks & Regards
Shivani
ShivaniK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance please post a new question.
Thanks & Regards
Shivani
