872 Discussions
icpx crash report compiling SLATE linear algebra library
chillenb
I'm trying to compile SLATE (https://github.com/icl-utk-edu/slate) with OneAPI 2025.0 toolchain. Unfortunately icpx crashed.
The command used to configure the code with CMake:
cmake -B build -S . \
-DCMAKE_CXX_COMPILER=icpx \
-DCMAKE_Fortran_COMPILER=ifx \
-DCMAKE_C_COMPILER=icx \
-Dblas=mkl \
-Dblas_threaded=1 \
-Dblas_fortran=ifort \
-Dgpu_backend=none \
-Dmkl_blacs=intelmpi
icpx crashed on src/internal/internal_gbnorm.cc. I've attached the output of the command with -save-temps -v, as requested. I don't have priority support, but the compiler team might still want to know about this bug.
chillenb
The bug seems related to the OpenMP implementation. Compilation of src/internal/internal_gbnorm.cc succeeds using Clang's OpenMP via the flag "-fopenmp".
Sravani_K_Intel
Thanks for reporting this bug, will escalate it to the Compiler team.
Sravani_K_Intel
@chillenb Upon further testing, I found that this bug has been fixed in 2025.1 Compiler release.
