icx: data corruption at -O2
cmelone
I am building main.c (attached) with icx
Intel(R) oneAPI DPC++/C++ Compiler 2023.2.0 (2023.2.0.20230622)
The expected output of the program is "0 1 2 3 4 5 6 7." However, when compiled with -O2, the application returns incorrect data. We suspect that icx is reversing the loop at L22-L23 and this results in data corruption.
[cmelone@shepard-login-0-1 bug]$ icx -O1 main.c
[cmelone@shepard-login-0-1 bug]$ ./a.out
0 1 2 3 4 5 6 7
[cmelone@shepard-login-0-1 bug]$ icx -O2 main.c
0 1 2 3 0 2 0 2.125
I am not able to reproduce this with icc.
Alex_Y_Intel
Happens on oneAPI DPC++/C++ Compiler 2024.2 too, escalated the issue to our engineering team.
cw_intel
I reported the issue to our internal team. Will let you know when the issue is fixed.
Chen
cw_intel
This is not a bug. The test case is violating ansi-alias semantics by casting (double * a) into (float *) and hence has undefined behavior. To get the same results as -O1, you can compile the code with option '-fno-strict-aliasing'.
