oneAPI 2025.3 DPC++ sycl hang
jimdempseyatthecove
Using oneAPI 2025.3 DPC++ hangs at startup where 2025.2 used to work.
Not, the hang occurs in a reduced program without sycl header.
IOW code equivalent to a "Hello World" hangs.
//#include <sycl/sycl.hpp>
#include <iostream>
int main() {
    std::cout << "Enumerate SYCL devices" << std::endl;
    // Get all available SYCL platforms
    //for (const auto& platform : sycl::platform::get_platforms()) {
    //    std::cout << "Platform: "
    //        << platform.get_info<sycl::info::platform::name>()
    //        << std::endl;
    //    // Get all devices for the current platform
    //    for (const auto& device : platform.get_devices()) {
    //        std::cout << "  Device: "
    //            << device.get_info<sycl::info::device::name>()
    //            << std::endl;
    //        // Query and print some key device properties
    //        std::cout << "    Vendor: "
    //            << device.get_info<sycl::info::device::vendor>()
    //            << std::endl;
    //        std::cout << "    Type: "
    //            << (device.is_cpu() ? "CPU" : device.is_gpu() ? "GPU" : "Other")
    //            << std::endl;
    //        std::cout << "    Max Compute Units: "
    //            << device.get_info<sycl::info::device::max_compute_units>()
    //            << std::endl;
    //        std::cout << "    Max Clock Frequency (MHz): "
    //            << device.get_info<sycl::info::device::max_clock_frequency>()
    //            << std::endl;
    //        std::cout << "    Global Memory Size (MB): "
    //            << device.get_info<sycl::info::device::global_mem_size>() / 1024 / 1024
    //            << std::endl;
    //        std::cout << "    Double Precision Support: "
    //            << (device.has(sycl::aspect::fp64) ? "Yes" : "No")
    //            << std::endl;
    return 0;
The hang point (IMHO) is waiting for a completion flag from the GPU,
00007FFA759B509F  int         3
00007FFA759B50A0  cmp         byte ptr [rcx+270h],0
00007FFA759B50A7  jne         00007FFA759B50C3
00007FFA759B50A9  nop         dword ptr [rax]
00007FFA759B50B0  movzx       eax,byte ptr [rcx+271h]
00007FFA759B50B7  nop
00007FFA759B50B8  test        al,al
00007FFA759B50BA  je          00007FFA759B50B0
00007FFA759B50BC  mov         byte ptr [rcx+270h],1
00007FFA759B50C3  ret
00007FFA759B50C4  int         3
Flag at [rcx+271h] never set
Call stack
Did something kill/replace the graphics driver? (e.g. Windows Update)
Jim Dempsey
jimdempseyatthecove
Note, pausing the hung program, opening a disassembly window, then issuing a step, places the program counter at the nop instruction. Opening the al register and setting the value from 0 to 1, then continue, the program returns and issues the cout.
Uncommenting the commented statements and doing the same. Produces the expected results.
Platform: Intel(R) oneAPI Unified Runtime over Level-Zero V2
  Device: Intel(R) Arc(TM) Pro B50 Graphics
    Vendor: Intel(R) Corporation
    Type: GPU
    Max Compute Units: 128
    Max Clock Frequency (MHz): 2600
    Global Memory Size (MB): 15876
    Double Precision Support: Yes
Platform: Intel(R) OpenCL
  Device: Intel(R) Core(TM) i9-14900K
    Type: CPU
    Max Compute Units: 32
    Max Clock Frequency (MHz): 0
    Global Memory Size (MB): 65291
Platform: Intel(R) OpenCL Graphics
    Type: GPU
    Type: CPU
Note 2, the hang occurs even after performing a repair on the driver (installed with gfx_win_101.6979.exe)
I do not know what changed.
Any information on a fix would be helpful.
Jim Dempsey
Sravani_K_Intel
Please upgrade to the latest driver available for your system as this issue has been addressed in recent driver updates.
