888 Discussions
problems about SYCL reduction variables using oneAPI
JamesFBM
Hi, I'm new to SYCL and am trying to run an example about reduction variables from the SYCL Specification with oneAPI 2023.0.0. I revise the code a little and the final version is shown as follows:
#include <iostream>
#include <sycl/sycl.hpp>
#include <numeric>
using namespace sycl;
int main() {
	buffer<int> valuesBuf{ 1024 };
		host_accessor a{ valuesBuf };
        // std::iota(a.begin(), a.end(), 0);
        std::iota(&(a[0]), &(a[1023]), 0);
	int sumResult = 0;
	buffer<int> sumBuf{ &sumResult, 1 };
	int maxResult = 0;
	buffer<int> maxBuf{ &maxResult, 1 };
	queue myQueue;
	myQueue.submit([&](handler& cgh) {
		auto inputValues = valuesBuf.get_access<access_mode::read>(cgh);
	auto sumReduction = reduction(sumBuf, cgh, plus<>());
	auto maxReduction = reduction(maxBuf, cgh, maximum<>());
	 cgh.parallel_for(range<1> {2048, 1024}, sumReduction, maxReduction,
		[=](nd_item<1> it, auto& sum, auto& max) {
			sum += inputValues[it.get_local_id()];
			max.combine(inputValues[it.get_global_id()]);
    cgh.parallel_for(nd_range<1> {2048, 1024}, sumReduction, maxReduction,
	        max.combine(inputValues[it.get_local_id()]);
	// assert(maxBuf.get_host_access()[0] == 1023 && sumBuf.get_host_access()[0] == 523776);
    std::cout << maxBuf.get_host_access()[0] << std::endl;
    std::cout << sumBuf.get_host_access()[0] << std::endl;
However, the program compiled with icpx in cmd does not work as expected. The program typically prints out nothing and exits with a meaningless value. The result is shown below:
C:\Users\a1595\Desktop\dr\c>icpx -fsycl c.cpp -o c.exe
C:\Users\a1595\Desktop\dr\c>c.exe
C:\Users\a1595\Desktop\dr\c>echo %ERRORLEVEL%
-1073740791​
I am wondering whether there is anything wrong with the code, compilation or anything else.
I am looking forward to any help. Thanks a lot.
SeshaP_Intel
Please find the below modified DPC++ source code which is producing the correct values after the execution.
#include <iostream>
#include <CL/sycl.hpp>
#include <numeric>
int main()
    buffer<int> valuesBuf { 1024 };
        host_accessor a { valuesBuf };
        std::iota(&a[0], &a[0] + 1024, 0);
    int sumResult = 0;
    buffer<int> sumBuf { &sumResult, 1 };
    int maxResult = 0;
    queue myQueue;
        cgh.parallel_for(nd_range<1> {1024, 256}, sumReduction, maxReduction,
                             sum+= inputValues[it.get_global_id()];
    std::cout << "maxReduction = "<<maxBuf.get_host_access()[0] << std::endl;
    std::cout << "sumReduction = "<<sumBuf.get_host_access()[0] << std::endl;
    return 0;
Please find the output screenshot below.
Hope this resolves your issue.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
#include <iostream>
#include <numeric>
int main()
    int sumResult = 0;
    int maxResult = 0;
    queue myQueue;
    return 0;
Thanks and Regards,
PC-1
Hi,  SeshaP,
Unfortunately I cannot compile you code in visual studio 2022..
Error message is "error : SYCL kernel cannot call a variadic function"
and "error : SYCL kernel cannot call an undefined function without SYCL_EXTERNAL attribute"
Could you help me with that?
JamesFBM
Hi, Sesha. Thanks a lot for your help. Your code works on my computer and I simply misunderstood the usage of nd_range.
SeshaP_Intel
Thanks for accepting our solution.
Please refer to the below output screenshot built on Visual Studio in Release Mode.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
