836 Discussions
"loop not unrolled" warnings when using oneDPL
blinkfrog
I am using the oneDPL library within the oneAPI 2024 base toolkit on a Windows system with Visual Studio. I've encountered a significant performance issue that appears to be indirectly caused by a large number of compiler warnings generated during the execution of the exclusive_scan operation on a CPU device, particularly when /O2 optimization is enabled.
Issue Description
Environment: Windows, Visual Studio, oneAPI 2024 base toolkit.
Operation: exclusive_scan in oneDPL.
Optimization Flag: /O2 optimization enabled.
Problem
Executing exclusive_scan generates a lot of warnings, which seem to be the primary factor in the drastic performance decrease. The repeated warning is:
`warning: parallel_backend_sycl.h:544:0: loop not unrolled: the optimizer was unable to perform the requested transformation; the transformation might be disabled or specified as part of an unsupported transformation ordering.`
Temporary Solution and Observations
Upon examining the file `Intel\oneAPI\dpl\2022.3\include\oneapi\dpl\pstl\hetero\dpcpp\parallel_backend_sycl.h`, I found the _ONEDPL_PRAGMA_UNROLL pragma at line #543. Commenting this line out stops these warnings and subsequently leads to a significant improvement in performance. This suggests that the performance issue is indirectly caused by the high volume of warnings rather than the unrolling process itself.
Inquiry
Is there an alternative approach to resolve this warning issue without directly altering the parallel_backend_sycl.h file? Are there known issues or updates regarding this behavior, or any workarounds you could recommend?
Attached is a VS project with reduced C++ file that reproduces this behavior, for your review and investigation.
Thank you for your assistance with this matter. I look forward to any guidance or updates you may provide.
NoorjahanSk_Intel
Thanks for your patience.
The issue raised by you has been targeted to be fixed in oneAPI 2024.1 version which will be released in the coming months. If the issue still persists with the new release, then you can start a new discussion for the community to investigate.
Please check the below Release notes for all the updates regarding the Intel oneAPI
https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-toolkit-release-notes.html
Please let us know if we can go ahead and close this case.
Thanks & Regards,
Noorjahan.
blinkfrog
Additional information. It seems this depends on the set size, but with smaller buffers the warning message specifies line #522, so, in this case, it is needed to comment out the line #521.
NoorjahanSk_Intel
We are also able to reproduce the issue at our end. We have reported this issue to the concerned development team. They are looking into your issue.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
blinkfrog
NoorjahanSk_Intel
Thanks for your confirmation.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
