I'm trying to compile a software using ICPX, Intel(R) oneAPI DPC++/C++ Compiler 2023.0.0 (2023.0.0.20221201).
ICPX seems to have some symbols redefined v/s an external library I'm using (over which I don't have control hence can't change), so, to avoid the issues, I'm attempting to add -Wl,-z,muldefs or -z muldefs as options to the ICPX command line. However, when doing so, ICPX complains in both cases:
icpx: fatal error: -z muldefs: 'linker' input unused [-Wunused-command-line-argument]
(I've also turned -Wfatal-errors on my project).
So, my question is: How would then be the proper way to pass arguments to the linker?
Thanks in advance.
Thanks for posting in the Intel forums.
Could you please provide us with the sample reproducer code and steps to reproduce the issue at our end?
Thanks & Regards
Shivani
As we did not hear back from you, could you please provide us with the details asked in my previous post?
Thanks & Regards
Shivani
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance please post a new question.
Thanks & Regards
Shivani
