1D - FFT
sicb0161
I am a newbie using the FFT, I have some question about the input and output data format using the FFT Functions.
[cpp]  DFTI_DESCRIPTOR *my_desc_handle;
  long status;
  status = DftiCreateDescriptor( &my_desc_handle, DFTI_SINGLE, DFTI_REAL, 1, N);
  status = DftiCommitDescriptor( my_desc_handle);
  status = DftiComputeForward( my_desc_handle, y);
  status = DftiFreeDescriptor( &my_desc_handle );[/cpp]
Well, my input data y is real. After the transformation y contains not only real but also imaginary data. Is there a workaround ?
thx
Dmitry_B_Intel
It depends on what you need from the spectrum y. If you want to discard the phase and use the power, you should use the magnitude (sqrt(re^2+im^2)) of the y's complex numbers.
Alternatively, if you needa real-to-real transform, look into trigonometric transforms section of MKL Refernce Manual.
Dima
Dmitry_B_Intel
Alternatively, if you needa real-to-real transform, look into trigonometric transforms section of MKL Reference Manual.
Dima
ArturGuzik
Valued Contributor I
Quoting - sicb0161
long status;
thx
if I recall correctly you need to use DFTISetValue and select (from many) options you need, say, something along the lines:
[cpp]! set packed format for output complex conjugate-symmetric data
status%flag=DFTISetValue(desc_handle, ....., .....)[/cpp]
where ..... go for named constants. (for example DFTI_REAL_REAL)
Take a look at Named Constants and storage schemes. I believe you'll find many good examples on disk.
A.
sicb0161
Dima
Thx Dima ,
Hi, yes I could do so, but I only want to have the real part of y. After computing the FFT, y contains imaginary and real data. To be more precise :
[cpp]y = (real part) if i = even,
       (imag part) if i = odd.[/cpp]
But y is only of length n , thus only containing half the data.
Thx
Dmitry_B_Intel
Right, for size=N real-to complex transform the y contains only N/2+1 complex values. The remaining values can be restored using conjugate-even symmetry of y: y[N-n]=conj(y).
Dima
