2D Convolution methode
KIM__ILTAEK
Matlab supports three methods when using conv2. As you can see from the reference site below, Full, Same, and Valid methods are supported.
https://johnloomis.org/ece563/notes/filter/conv/convolution.html
Is it possible to add an option like this using vsldConvExec? Or if there is any other way, please advise.
Gennady_F_Intel
here is what I see on my part.
Math kernel Lib Runtime : 1.859sec
Naive Algorithm Runtime : 1.157sec
Press any key to continue . . .
Yes, the naive implementation is faster then what mkl suggested. You may submit the request to the intel online service center or as I already suggested you - check the IPP library. The Conv/Corr functionality from IPP is very much optimized.
Gennady_F_Intel
I see two options: #1. You could try to submit the Feature Request against Intel MKL to add these options and #2 - Try to take Intel IPP which already supported all of the modes you are looking for. Please refer to the IPP Developer Reference follow this link:https://software.intel.com/en-us/ipp-dev-reference-conv
KIM__ILTAEK
Thank for your reply.
First, we implemented convolution by full method and crop by input size.
However, it is slower than the navie algorithm. I am developing on windows 10 with i7-5960X.
Below is my test code result. Please advise if I have something wrong. Code is attached. Please review.
Math kernel lib runtime : 1.282sec
Naive Algorithm runtime : 0.234sec
Gennady_F_Intel
At first glance, everything is correct with the mkl part but I didn't try to build the case. Is it requires to build from VS as I see the test included only stdafx.h?
KIM__ILTAEK
The project file was compressed and uploaded. The development environment is using visual studio 2015.
Please review together.
Gennady_F_Intel
KIM__ILTAEK
Thank you for your confirm.
I will check it again using IPP.
