A'*B using mkl_dcscmm
Zaiwen
I tried mkl_dcscmm to compute both A*B and A'*B  using a Matlab mex file (64-bit Linux, Matlab 2013a and 2013b) similar to the code posted in
http://software.intel.com/en-us/forums/topic/472320
MKL is faster than matlab's own implemention on A*B. It is strange that MKL is slower than matlab's version on A'*B and the results are slightly different.
(the first column of cpu is from matlab's implementation and the second column is from MKL)
seed:  76080079, A*B: err 0.00e+00, cpu (0.91, 0.44), A'*B: err 1.43e-09, cpu (0.76, 0.71)
seed:  66432737, A*B: err 0.00e+00, cpu (0.91, 0.43), A'*B: err 1.43e-09, cpu (0.75, 0.79)
seed:  90643494, A*B: err 0.00e+00, cpu (0.92, 0.45), A'*B: err 1.43e-09, cpu (0.77, 0.88)
seed:  75317986, A*B: err 0.00e+00, cpu (0.94, 0.46), A'*B: err 1.45e-09, cpu (0.75, 0.82)
seed:  31023079, A*B: err 0.00e+00, cpu (0.92, 0.42), A'*B: err 1.43e-09, cpu (0.75, 0.80)
seed:  86467634, A*B: err 0.00e+00, cpu (0.94, 0.48), A'*B: err 1.44e-09, cpu (0.76, 0.86)
seed:  19834911, A*B: err 0.00e+00, cpu (0.93, 0.61), A'*B: err 1.42e-09, cpu (0.78, 0.76)
seed:  79273667, A*B: err 0.00e+00, cpu (0.93, 0.48), A'*B: err 1.43e-09, cpu (0.75, 0.82)
seed:  11976366, A*B: err 0.00e+00, cpu (0.93, 0.45), A'*B: err 1.42e-09, cpu (0.78, 0.89)
seed:  16420430, A*B: err 0.00e+00, cpu (0.92, 0.40), A'*B: err 1.43e-09, cpu (0.75, 0.80)
My codes are attached. It can be compiled as
mex -O  -largeArrayDims  -output sfmult mkl-sfmult-v1.cpp
A*B and A'*B can be computed as sfmult(A, B, 1) and sfmult(A, B, 2), respectively.
Although A'*B can also be computed as sfmult(A', B, 1) by first doing the transpose, it is better to provide the A matrix and use the flag of transpose inside mkl_dcscmm.
Any suggestion or comment is welcome. Thanks!
TimP
Performance differences look small enough that they could be due to any of several factors:
1) apparently, you didn't invoke auto-vectorization.  Even gprof ought to show whether that makes a difference.
2) differences (possibly accidental) in data alignment or total cache usage
Zaiwen
Thanks a lot for the quick feedback. I am quite confused by the two factors.
*) Why the correctness depends on auto-vectorization and data alignment or total cache usage?
*) The error of A'*B can become larger if the size of the matrix increases. But the results of A*B are the same as these computed by Matlab.
*) Since these two operations have to be called tens to hundreds of times in my application, the performance differences can be quite large. Hence, I hope to first figure out the reason in some simple random examples.
I am wondering if there is a bug in mkl_dcscmm when the transpose of A is used.
VipinKumar_E_Intel
Please refer the article on the MKL feature called Conditional Numerical Reproducibility to get more details on causes of incorrect results .
http://software.intel.com/en-us/articles/introduction-to-the-conditional-numerical-reproducibility-cnr
From MKL 11.1 onwards, we also support CNR mode on unaligned data.  Can you try MKL 11.1 and see you still see the problem?
--Vipin
