A bug in dcg_get?
Zbigniew_L_
I wrote a small code calling the RCI CG routine with the ILU0 preconditioner. The code is attached. The code returns an incorrect vector of all zeros as a solution. I have noticed that the vector tmp contains the correct solution but it is not transfered to the vector x (= solution).
Zbigniew
Gennady_F_Intel
is that linux or windows?
Alexander_K_Intel2
I see that you call dcg_get to return correct value of solution, but dcg_get return only current number of iteration
Output Parameters
itercount
INTEGER. Returns the current iteration number.
Alex
Zbigniew_L_
It is Linux (64-bit).
Zbigniew_L_
Here is my output:
tmp:
tmp[0]=-0.0909091, tmp[1]=-0.181818, tmp[2]=-0.272727, tmp[3]=-0.363636, tmp[4]=-0.454545, tmp[5]=-0.545455, tmp[6]=-0.636364, tmp[7]=-0.727273, tmp[8]=-0.818182, tmp[9]=-0.909091,
# of iterations = 0
solution x:
x[0]=0, x[1]=0, x[2]=0, x[3]=0, x[4]=0, x[5]=0, x[6]=0, x[7]=0, x[8]=0, x[9]=0,
It is evident that the solution (x) is not correct.
Zbigniew
Zbigniew_L_
I should have asked the question "A bug in dcg?" because it is dcg which returns an incorrect solution (all zeros).
Also, why the number of iterations is 0?
Zbigniew
