A documentation ambiguity with DGEEV
utab
Dear developers,
I have a problem with the documentation of the DGEEV function on page 1030 of the pdf manual, namely, the lwork parameter, I am copying directly from the manual,
The dimension of the array work.
Constraint:
lwork ≥ max(1, 3n), and if jobvl = 'V' or jobvr = 'V', lwork <
max(1, 4n) (for real flavors);
lwork < max(1, 2n) (for complex flavors).
For good performance, lwork must generally be larger.
And for my problem I need to compute only the right eigenvectors, so I am setting jobvr = 'V', jobvl = 'N' however setting
lwork = 3*n + 5(or 4*n)
DGEEV results in -13 error for a problem size of 82X82. However setting it to 5*n or 10*n works fine. So could you please make this point clear for me?
Umut
Zhang_Z_Intel
I'll get some clarification from the MKL team about the description for lwork. Meanwhile, you can set lwork to -1 for the first call to DGEEV. When it returns it will tell you the optimal value ( via work(1) ) you should use for lwork. Then, you call DGEEV again with this optimal lwork value to do the actual computation.
Konstantin_A_Intel
Hi Umut,
This definitely looks like a mistake/misprint in MKL documentation. lwork should be constraint like “not less than” rather than “less than”. All "<" values in the description of lwork should be read as ">=".
We’ll fix it in the next release of MKL. Thank you for your attention!
Konstantin
