A problem with installation
Aleksandar_O_
Hi everybody!
I tried to install l_mkl_2017.2.174 (Manual RPM) on Ubuntu 17.04 but I did not succeed.
~/Downloads/l_mkl_2017.2.174/rpm$ rpm -ivh --nodeps --ignorearch --force-debian *.rpm
warning: intel-comp-l-all-vars-174-17.0.2-174.noarch.rpm: Header V4 RSA/SHA256 Signature, key ID 1911e097: NOKEY
Preparing...                          ################################# [100%]
Updating / installing...
   1:intel-tbb-libs-174-2017.4-174    ################################# [  1%]
error: unpacking of archive failed on file /opt/intel: cpio: mkdir
error: intel-tbb-libs-174-2017.4-174.noarch: install failed
   2:intel-openmp-l-all-174-17.0.2-174################################# [  3%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux/compiler: cpio: mkdir
error: intel-openmp-l-all-174-17.0.2-174.i486: install failed
   3:intel-mkl-ps-common-174-2017.2-17################################# [  4%]
error: intel-mkl-ps-common-174-2017.2-174.i486: install failed
   4:intel-openmp-l-ps-libs-174-17.0.2################################# [  5%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux/compiler/lib/intel64_lin_mic: cpio: mkdir
error: intel-openmp-l-ps-libs-174-17.0.2-174.x86_64: install failed
   5:intel-mkl-ps-ss-tbb-174-2017.2-17################################# [  7%]
error: intel-mkl-ps-ss-tbb-174-2017.2-174.i486: install failed
   6:intel-mkl-ps-mic-174-2017.2-174  ################################# [  8%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux/mkl: cpio: mkdir
error: intel-mkl-ps-mic-174-2017.2-174.x86_64: install failed
   7:intel-mkl-ps-doc-2017.2-174      ################################# [ 10%]
error: intel-mkl-ps-doc-2017.2-174.noarch: install failed
   8:intel-mkl-common-174-2017.2-174  ################################# [ 11%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174: cpio: mkdir
error: intel-mkl-common-174-2017.2-174.noarch: install failed
   9:intel-mkl-ps-common-174-2017.2-17################################# [ 12%]
error: intel-mkl-ps-common-174-2017.2-174.noarch: install failed
  10:intel-mkl-ps-doc-jp-2017.2-174   ################################# [ 14%]
error: unpacking of archive failed on file /opt/intel/documentation_2017/ja: cpio: mkdir
error: intel-mkl-ps-doc-jp-2017.2-174.noarch: install failed
  11:intel-mkl-ps-tbb-mic-174-2017.2-1################################# [ 15%]
error: intel-mkl-ps-tbb-mic-174-2017.2-174.x86_64: install failed
  12:intel-openmp-l-ps-libs-jp-174-17.################################# [ 16%]
error: intel-openmp-l-ps-libs-jp-174-17.0.2-174.x86_64: install failed
  13:intel-mkl-ps-common-c-174-2017.2-################################# [ 18%]
error: intel-mkl-ps-common-c-174-2017.2-174.noarch: install failed
  14:intel-mkl-ps-common-jp-174-2017.2################################# [ 19%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/licensing/mkl/ja: cpio: mkdir
error: intel-mkl-ps-common-jp-174-2017.2-174.noarch: install failed
  15:intel-openmp-l-ps-libs-jp-174-17.################################# [ 21%]
error: intel-openmp-l-ps-libs-jp-174-17.0.2-174.i486: install failed
  16:intel-mkl-ps-ss-tbb-174-2017.2-17################################# [ 22%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux: cpio: mkdir
error: intel-mkl-ps-ss-tbb-174-2017.2-174.x86_64: install failed
  17:intel-psxe-common-doc-2017.2-050 ################################# [ 23%]
error: intel-psxe-common-doc-2017.2-050.noarch: install failed
  18:intel-psxe-common-050-2017.2-050 ################################# [ 25%]
error: unpacking of archive failed on file /opt/intel/parallel_studio_xe_2017.2.050: cpio: mkdir
error: intel-psxe-common-050-2017.2-050.noarch: install failed
  19:intel-openmp-l-all-174-17.0.2-174################################# [ 26%]
error: intel-openmp-l-all-174-17.0.2-174.x86_64: install failed
  20:intel-mkl-rt-174-2017.2-174      ################################# [ 27%]
error: intel-mkl-rt-174-2017.2-174.x86_64: install failed
  21:intel-mkl-rt-174-2017.2-174      ################################# [ 29%]
error: intel-mkl-rt-174-2017.2-174.i486: install failed
  22:intel-mkl-psxe-050-2017.2-050    ################################# [ 30%]
error: unpacking of archive failed on file /opt/intel/parallel_studio_xe_2017.2.050/licensing: cpio: mkdir
error: intel-mkl-psxe-050-2017.2-050.noarch: install failed
  23:intel-mkl-ps-tbb-mic-rt-174-2017.################################# [ 32%]
error: intel-mkl-ps-tbb-mic-rt-174-2017.2-174.x86_64: install failed
  24:intel-mkl-ps-ss-tbb-rt-174-2017.2################################# [ 33%]
error: intel-mkl-ps-ss-tbb-rt-174-2017.2-174.x86_64: install failed
  25:intel-mkl-ps-ss-tbb-rt-174-2017.2################################# [ 34%]
error: intel-mkl-ps-ss-tbb-rt-174-2017.2-174.i486: install failed
  26:intel-mkl-ps-rt-jp-174-2017.2-174################################# [ 36%]
error: intel-mkl-ps-rt-jp-174-2017.2-174.x86_64: install failed
  27:intel-mkl-ps-rt-jp-174-2017.2-174################################# [ 37%]
error: intel-mkl-ps-rt-jp-174-2017.2-174.i486: install failed
  28:intel-mkl-ps-pgi-rt-174-2017.2-17################################# [ 38%]
error: intel-mkl-ps-pgi-rt-174-2017.2-174.x86_64: install failed
  29:intel-mkl-ps-pgi-f-174-2017.2-174################################# [ 40%]
error: intel-mkl-ps-pgi-f-174-2017.2-174.x86_64: install failed
  30:intel-mkl-ps-pgi-c-174-2017.2-174################################# [ 41%]
error: intel-mkl-ps-pgi-c-174-2017.2-174.x86_64: install failed
  31:intel-mkl-ps-pgi-174-2017.2-174  ################################# [ 42%]
error: intel-mkl-ps-pgi-174-2017.2-174.x86_64: install failed
  32:intel-mkl-ps-mic-rt-jp-174-2017.2################################# [ 44%]
error: intel-mkl-ps-mic-rt-jp-174-2017.2-174.x86_64: install failed
  33:intel-mkl-ps-mic-rt-174-2017.2-17################################# [ 45%]
error: intel-mkl-ps-mic-rt-174-2017.2-174.x86_64: install failed
  34:intel-mkl-ps-mic-f-174-2017.2-174################################# [ 47%]
error: intel-mkl-ps-mic-f-174-2017.2-174.x86_64: install failed
  35:intel-mkl-ps-mic-cluster-rt-174-2################################# [ 48%]
error: intel-mkl-ps-mic-cluster-rt-174-2017.2-174.x86_64: install failed
  36:intel-mkl-ps-mic-cluster-174-2017################################# [ 49%]
error: intel-mkl-ps-mic-cluster-174-2017.2-174.x86_64: install failed
  37:intel-mkl-ps-mic-c-174-2017.2-174################################# [ 51%]
error: intel-mkl-ps-mic-c-174-2017.2-174.x86_64: install failed
  38:intel-mkl-ps-gnu-f-rt-174-2017.2-################################# [ 52%]
error: intel-mkl-ps-gnu-f-rt-174-2017.2-174.x86_64: install failed
  39:intel-mkl-ps-gnu-f-rt-174-2017.2-################################# [ 53%]
error: intel-mkl-ps-gnu-f-rt-174-2017.2-174.i486: install failed
  40:intel-mkl-ps-gnu-f-174-2017.2-174################################# [ 55%]
error: intel-mkl-ps-gnu-f-174-2017.2-174.x86_64: install failed
  41:intel-mkl-ps-gnu-f-174-2017.2-174################################# [ 56%]
error: intel-mkl-ps-gnu-f-174-2017.2-174.i486: install failed
  42:intel-mkl-ps-f95-mic-174-2017.2-1################################# [ 58%]
error: intel-mkl-ps-f95-mic-174-2017.2-174.x86_64: install failed
  43:intel-mkl-ps-f95-common-174-2017.################################# [ 59%]
error: intel-mkl-ps-f95-common-174-2017.2-174.noarch: install failed
  44:intel-mkl-ps-f95-174-2017.2-174  ################################# [ 60%]
error: intel-mkl-ps-f95-174-2017.2-174.x86_64: install failed
  45:intel-mkl-ps-f95-174-2017.2-174  ################################# [ 62%]
error: intel-mkl-ps-f95-174-2017.2-174.i486: install failed
  46:intel-mkl-ps-doc-f-jp-2017.2-174 ################################# [ 63%]
error: intel-mkl-ps-doc-f-jp-2017.2-174.noarch: install failed
  47:intel-mkl-ps-doc-f-2017.2-174    ################################# [ 64%]
error: intel-mkl-ps-doc-f-2017.2-174.noarch: install failed
  48:intel-mkl-ps-doc-c-jp-2017.2-174 ################################# [ 66%]
error: unpacking of archive failed on file /opt/intel/documentation_2017/ja/mkl: cpio: mkdir
error: intel-mkl-ps-doc-c-jp-2017.2-174.noarch: install failed
  49:intel-mkl-ps-common-f-64bit-174-2################################# [ 67%]
error: intel-mkl-ps-common-f-64bit-174-2017.2-174.x86_64: install failed
  50:intel-mkl-ps-common-f-174-2017.2-################################# [ 68%]
error: intel-mkl-ps-common-f-174-2017.2-174.noarch: install failed
  51:intel-mkl-ps-common-f-174-2017.2-################################# [ 70%]
error: intel-mkl-ps-common-f-174-2017.2-174.i486: install failed
  52:intel-mkl-ps-common-64bit-174-201################################# [ 71%]
error: intel-mkl-ps-common-64bit-174-2017.2-174.x86_64: install failed
  53:intel-mkl-ps-cluster-rt-174-2017.################################# [ 73%]
error: intel-mkl-ps-cluster-rt-174-2017.2-174.x86_64: install failed
  54:intel-mkl-ps-cluster-f-174-2017.2################################# [ 74%]
error: intel-mkl-ps-cluster-f-174-2017.2-174.noarch: install failed
  55:intel-mkl-ps-cluster-c-174-2017.2################################# [ 75%]
error: intel-mkl-ps-cluster-c-174-2017.2-174.noarch: install failed
  56:intel-mkl-ps-cluster-64bit-174-20################################# [ 77%]
error: intel-mkl-ps-cluster-64bit-174-2017.2-174.x86_64: install failed
  57:intel-mkl-ps-cluster-174-2017.2-1################################# [ 78%]
error: intel-mkl-ps-cluster-174-2017.2-174.noarch: install failed
  58:intel-mkl-gnu-rt-174-2017.2-174  ################################# [ 79%]
error: intel-mkl-gnu-rt-174-2017.2-174.x86_64: install failed
  59:intel-mkl-gnu-rt-174-2017.2-174  ################################# [ 81%]
error: intel-mkl-gnu-rt-174-2017.2-174.i486: install failed
  60:intel-mkl-gnu-c-174-2017.2-174   ################################# [ 82%]
error: intel-mkl-gnu-c-174-2017.2-174.x86_64: install failed
  61:intel-mkl-gnu-c-174-2017.2-174   ################################# [ 84%]
error: intel-mkl-gnu-c-174-2017.2-174.i486: install failed
  62:intel-mkl-gnu-174-2017.2-174     ################################# [ 85%]
error: intel-mkl-gnu-174-2017.2-174.x86_64: install failed
  63:intel-mkl-gnu-174-2017.2-174     ################################# [ 86%]
error: intel-mkl-gnu-174-2017.2-174.i486: install failed
  64:intel-mkl-doc-c-2017.2-174       ################################# [ 88%]
error: unpacking of archive failed on file /opt/intel/documentation_2017: cpio: mkdir
error: intel-mkl-doc-c-2017.2-174.noarch: install failed
  65:intel-mkl-doc-2017.2-174         ################################# [ 89%]
error: intel-mkl-doc-2017.2-174.noarch: install failed
  66:intel-mkl-common-eula-174-2017.2-################################# [ 90%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/licensing: cpio: mkdir
error: intel-mkl-common-eula-174-2017.2-174.noarch: install failed
  67:intel-mkl-common-c-64bit-174-2017################################# [ 92%]
error: intel-mkl-common-c-64bit-174-2017.2-174.x86_64: install failed
  68:intel-mkl-common-c-174-2017.2-174################################# [ 93%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/examples/examples_core_c.tgz;58fe1f5a: cpio: open
error: intel-mkl-common-c-174-2017.2-174.noarch: install failed
  69:intel-mkl-common-c-174-2017.2-174################################# [ 95%]
error: intel-mkl-common-c-174-2017.2-174.i486: install failed
  70:intel-mkl-174-2017.2-174         ################################# [ 96%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib: cpio: mkdir
error: intel-mkl-174-2017.2-174.x86_64: install failed
  71:intel-mkl-174-2017.2-174         ################################# [ 97%]
error: intel-mkl-174-2017.2-174.i486: install failed
  72:intel-compxe-pset-050-2017.2-050 ################################# [ 99%]
error: unpacking of archive failed: cpio: mkdir
error: intel-compxe-pset-050-2017.2-050.noarch: install failed
  73:intel-comp-l-all-vars-174-17.0.2-################################# [100%]
error: unpacking of archive failed on file /opt/intel/compilers_and_libraries_2017.2.174/licensing/ja: cpio: mkdir
error: intel-comp-l-all-vars-174-17.0.2-174.noarch: install failed
machine information: 4.10.0-19-generic #21-Ubuntu SMP Thu Apr 6 17:04:57 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
distrubitive: Ubuntu 17.04 \n \l
MKL package name: l_mkl_2017.2.174
Jing_Xu
sudo rpm -ivh --nodeps --ignorearch --force-debian *.rpm
Aleksandar_O_
@Jing X.
Thank you very much.
How can I verify that I install Intel MKL?
