A question about optimization solver
bingo_gmwu
I wrote a program with Optimization [Trust Region] solvers. But I found it can not run on the PC with Intel Pentium 4 Processors 520. What can I do to make it work? Is it related to the project properties?
Gennady_F_Intel
It's not clear - what do you mean by "it can not run on the PC with Intel Pentium 4 Processors 520"?
What are the symptoms? What MKLversion you are using? What is your linking line?
--Gennady
bingo_gmwu
The MKL version is V10.1.1. I use VC9 for coding. Released program closed itself without any promotion on Pentium 4 520. I included mkl_c_dll.lib mkl_solver.lib libguide40.lib into the linking lines.
ArturGuzik
Valued Contributor I
What is your "environment"? VisualStudio (windows) or Eclipse (linux/unix). How you run the code? from command line, from within IDE?
what you mean by "promotion"? Is the code working in Debug mode?
A.
Gennady_F_Intel
It seems that the problem with the improper linking like you are using: for example for win32,
Please try to use the following linking line for static linking:
mkl_solver.lib mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
or for dynamic:
mkl_solver.lib mkl_intel_c_dll.lib mkl_intel_thread_dll.lib mkl_core_dll.lib libiomp5md.lib
More info: how to link your application with Intel MKL, please see userguide
--Gennady
bingo_gmwu
Quoting - ArturGuzik
A.
Thanks for your reply. Yes, my environment is VisualStudio. I run the program from the windows explorer. There is no IDE installed on the target computer.
Sorry, "promotion" means prompt, I wrote wrong words. I means there is no error message shown. The code works in release mode.
bingo_gmwu
or for dynamic:
--Gennady
Thanks for your reply. I also thought I used improper linking lines. But it seemed not be easy to find out the right one from the userguide.
I tried your suggestion. But there is an error message:
OMP Error #15: initialize libiomp5md.dll. but found libguide40.dll already initialized.
ArturGuzik
Check this KB article first.
A.
