A question on syntax of ?gemm.
woshiwuxin
Hi, eveyone. I have a simple question on the syntax of ?gemm.
In Intel MKL Reference Manual, the syntax of dgemm is
dgemm(transa, transb, m, n, k, alpha, a, lda, b, ldb, beta, c, ldc)
The parameter description of beta is "When beta is equal to zero, then c need not be set on input". I just don't quite understand the meaning of "c need not be set on input". If I merely want to do a matrix multiplication, say c=matmul(a,b). According to the description of ?gemm, c:=alpha*op(a)*op(b)+beta*c, I set beta equal zero. I expect the result should be c:=alpha*op(a)*op(b), however, what I get is c equals zero! So, what's the problem? What's the meaning of "c need not be set on input"?
Thanks in advance!
woshiwuxin
Thank you, Victor!
I just find somehow I started a duplicated thread with the same context. I'm sorry about that!
