Another application of dcopy subroutine
Hyoun-tae_Hwang
Hello all,
I am trying to apply dcopy to my parallel codes.In that, I want to chop one big array into several small arrays which sizes are defined by the number of threads applied.
For example,
* big_array(1~100)can beseparated into4 smallarrays such as small_array1(1~25),small_array2(26~50), small_array3(51~75), small_array4(76~100).
In this case, the small_array1,2,3, and 4 will copy values in the big_array so i need to assign the range which the small_arrays will copy from the big_array.
Rough idea for this function is
dcopy1(start,end,big_array,indx,small_array1,indx)
I am wondering if you have any ideas about this. Any comments will be helpful!
Cheers,
mecej4
That would be the Fortran-77 approach. In Fortran 2003, you can do:
[fortran]subroutine sub(A,N,...)
real(wp), dimension(N) :: A
real(wp),allocatable, dimension(:) :: A1,A2,A3
nby3=N/3       ! N should be an exact multiple of 3
A1=A(1:nby3); A2=A(nby3+1:2*nby3); A3=A(2*nby3+1:N)
[/fortran]
How to go about this depends on what fate you have in store for the pieces so extracted.
Gennady_F_Intel
moreover it would be faster then using dcopy for such cases.
Hyoun-tae_Hwang
Thank you for your response. It seems a good idea.
By the way, the output variables (A1,A2,A3)will bedepend on the number of threadassigned.
So,I am wondering ifIuse two dimensional arrays such as
subroutine sub(A,N,start,end,A1,numthread)
real(wp),allocatable, dimension(:,:) :: A1
A1(start(1):end(1),1) = A(start(1):end(1));
A1(start(2):end(2),2) = A(start(2):end(2));
A1(start(numthread):end(numthread),numthread)=A(start(numthread):end(numthread))
end subroutine sub
Hyoun-tae_Hwang
Okay, then I will try it. Thanks
