7303 Discussions
Any problems calling vml routines this way ??
Deleted_U_Intel
I have been playing around with ways to use vml functions more efficiently and have come up with the following technique (c++/cli) which appears to work faster, and take up less memory (than having the last parameter be a blank target array).
Can anyone tell me if there might be any issues calling the functions this way ??
// CODE SNIPPET //
// __cdecl //
#define N 5
int n = N;
array^ x = gcnew array(N);
array^ y = gcnew array(N);
for(i = 0; i < n; i++){
x = static_cast(i);
y = static_cast(i * 2.0);
pin_ptr xptr = &x[0];
pin_ptr yptr = &y[0];
vdmul( &n, xptr, yptr, yptr );
for (i = 0; i < n; i++)
Console::Write(y + " ");
// Pls note that using the c-interface in this way will throw an error
// i.e. vdAdd(n, x, y, y); //c2664 error
