Are VSL Routines ThreadSafe?
Pierpaolo_M_
I have written a simple code to generate Random Numbers using VSL Routines. It is an OpenMP code written in Fortran:
INCLUDE "mkl_vsl.f90"
program vsl_ex
use omp_lib
use mkl_vsl_type
use mkl_vsl
implicit none
integer :: k,errcode
integer, parameter :: nvp=48, n=10, brng=VSL_BRNG_MT2203
integer, parameter :: method=VSL_RNG_METHOD_GAUSSIAN_ICDF
TYPE (VSL_STREAM_STATE),DIMENSION(nvp) :: stream
double precision,dimension(n), save :: r
double precision, parameter :: a=0.0, sigma=1.0
!$OMP THREADPRIVATE (r)
CALL MKL_SET_NUM_THREADS(nvp)
DO k=1,nvp
  errcode=vslNewStream(stream(k),brng+k-1,777)
END DO
!$OMP PARALLEL DO PRIVATE(k,errcode) SHARED(stream)
DO k=1,nvp
!  errcode=k
!!$OMP CRITICAL
  errcode=vdRngGaussian(method, stream(k), n, r, a, sigma )
!!$OMP END CRITICAL
END DO
!$OMP END PARALLEL DO
END program vsl_ex
When i run it i receive exit code equal to zero, so it seems that everything is fine, but when i use Intel Inspector i receive a race condition:
P1: Error: Data race: New
 P1.27: Error: Data race: New
  /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto.f90(24): Error X54: Write: Function MAIN__$omp$parallel_for@20: Module /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto
  Code snippet:
   22  !  errcode=k
   23  !!$OMP CRITICAL
  >24    errcode=vdRngGaussian(method, stream(k), n, r, a, sigma )
   25
   26  !!$OMP END CRITICAL
  Stack (1 of 1 instance(s))
  >libmkl_intel_lp64.so!vdrnggaussian_ - /opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/libmkl_intel_lp64.so:0x5432c6
   pluto!MAIN__$omp$parallel_for@20 - /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto.f90:24
   pluto!vsl_ex - /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto.f90:20
   pluto!main - /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto:0xca9
   pluto!_start - /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto:0xbb4
  /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto.f90(24): Error X55: Read: Function MAIN__$omp$parallel_for@20: Module /home/pierpaolo/PIC/NIS/Hybrid/DOUBLEINT/PROVA/pluto
  Code snippet:
   22  !  errcode=k
   23  !!$OMP CRITICAL
   25
  >libmkl_intel_lp64.so!vdrnggaussian_ - /opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/libmkl_intel_lp64.so:0x54327b
I compile this program in this way:
ifort -O0 -g -debug inline-debug-info -mcmodel medium -shared-intel -qopenmp -I/opt/intel/composer_xe_2015.2.164/mkl/include -o pluto pluto.f90 -L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -lpthread -lm -ldl
The only way to overcome this is if i use $OMP CRITICAL when i call vdRngGaussian
Is there a problem in my code or is it normal that i have to use CRITICAL directive to avoid race condition as Intel Inspector says?
If i understood well, VSL routines are thredsafe, so why am i seeing a data race when different threads call a VSL routine? I have tried also other distributions with same results.
Thanks in advance
Pierpaolo
Vladislav_V_Intel
Hi Pierpaolo,
Your code is fine and there is no need to add $OMP CRITICAL. These reports are known false positives when profiling MKL applications with Inspector.
Vlad V.
Vladislav_V_Intel
Hi Pierpaolo,
Vlad V.
Pierpaolo_M_
Hi Vlad,
Thanks for your reply.
Pierpaolo
