7301 Discussions
Are negative strides in FFT signal data vectors supported?
Paul1
In the MKL Intel documentation, I don't see any mention that negative strides are support for FFT's - as they are for convolution and correlation.
Are negative strides supported in the MKL FFT library?
I can get negative strides to work (w/ no offset) but I have to futz with L0 and L1 in ways I wouldn't expect. If L1 < 0 then we must have L0 = |stride| - 1. For example if L1 = -3, the L0 must be 2 (in other words I set theDFTI_INPUT_STRIDES parameter with an array [2, -3] for a 1D FFT, and the FFT algorithm indexes through my input data in reverse order w/ stride 3).
xj = X(1 +L0 +L1 *j) = X(3 - 3*j)
What is the explanation for this? I would have expected the offset L0 to be something like the size of the input array.
Thank you,
Paul
CenterSpace Software
Ying_H_Intel
Quoting - paulshirkey
Thank you,
Paul
Hi Paul,
As i knew, theFFT in current MKL version don't support negative strides. But MKL should havea set of routines routines in VSL for convolution and correlationdirectly . They alsoincluded fourier implementation.You may try them. Please see more from mkl manual mklman.pdf=>chapter 10 Statistical Functions.
Ying
Ying_H_Intel
Thank you,
Paul
Hi Paul,
Ying
Paul1
Quoting - Ying H (Intel)
Hi Paul,
Ying
Thanks Ying.
I'm using the routines in VSL succesfully.
Thanks again for the answer.
Paul
