7298 Discussions
Avoid matrix inversion is it always possible?
Gianluca_G_1
We need to solve a linear system with a dense matrix of complex numbers.
When the size of the matrix is lower than 4 GB (Microsoft limits for 64 bit systems) we can use MKL routines directly to solve:
{x} = {b}
Instead when the matrix is bigger than 4 GB we divide the matrix in blocks:
The linear system becomes:
From (1) we obtain:
Solving equation (6) the solution x2 is obtained.
Using x2 in (3) it is easy to calculate x1.
This algorithm is interesting but introduces a matrix inversion.
This is a big problem when the linear system is ill conditioned.
Any suggestion to solve the problem avoiding the matrix inversion?
Thankyou
Gianluca
Alexander_K_Intel2
