7298 Discussions
[BUG] Memory leak in cluster pardiso solver when n=1
tlcfem
It seems like when n=1, although makes little sense in practice (but indeed is a valid matrix size), there is a memory leak issue in the cluster pardiso solver.
The attached reproducer is an abridged version of the example file `cl_solver_unsym_c.c`.
Compile and run the executable, the output starts with the following.
*** Error in PARDISO ( insufficient_memory) error_num= 1
*** Error in PARDISO memory allocation: MATCHING_REORDERING_DATA, allocation of 1 bytes failed
total memory wanted here: 142 kbyte
=== PARDISO: solving a real nonsymmetric system ===
Matrix checker is turned ON
With address sanitizer on, it looks like `mm_internal_malloc` is leaking memory.
==3948==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 128 byte(s) in 1 object(s) allocated from:
#0 0x7f54bcefd9c7 in malloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cpp:69
#1 0x5641c65c4c1c in mm_internal_malloc (/home/runner/work/ezp/ezp/build/pardiso.memleak+0xd8c1c) (BuildId: 147c1dc7a67f9a1d99f4d13e95bd2136fa286a0f)
SUMMARY: AddressSanitizer: 128 byte(s) leaked in 1 allocation(s).
It is reproduced in a standard environment, see the following GitHub workflow.
https://github.com/TLCFEM/ezp/actions/runs/15502135308
Seems to be a memory issue?
Chao_Y_Intel
Intel MKL use internal buffers to facilitate better performance.  These internal buffers may be reported as leaked memory.
Can you check this article, and see if some APIs/environment can help to remove it:
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2025-1/avoiding-memory-leaks-in-onemkl.html
thanks,
Chao
tlcfem
Calling mkl_disable_fast_mm does not help, see the following workflow.
https://github.com/TLCFEM/ezp/actions/runs/15530089687
Noting the information,
It seems like some faulty parameters are passed to memory allocation, because when n>1 there is no such an error.
Ruqiu_C_Intel
Thank you for submitting the issue.
We have reproduced the issue with the reproducer. We will update this post once there are further improvements.
Ruqiu
Fengrui
This issue has been fixed in the oneMKL 2025.3 release. Please give it a try!
