7298 Discussions
[BUG] access violation after dsymv call when debugging on AMD CPU
michaelkonecny
this is likely related to [BUG] dsymv corrupts the xmm7 register on AMD processors,
but the behaviour is slightly different, so I decided to report it too, in case it's caused by a different problem.
Versions used are the same: Visual Studio Community 17.14.14 and oneAPI 2024.1 on Windows.
When I build the bug reproducer from the aforementioned bug from the `direct_mkl_link-crash` branch:
https://bitbucket.org/k2fem/bug_intel_mkl_symv/src/direct_mkl_link-crash/
and run and debug the Debug configuration of the bug_mkl project, I get an access violation exception on line 21 of solve_sym_ldl_mod.f90:
if (info /= 0) b = IEEE_VALUE(b, IEEE_POSITIVE_INF)
The problem occured on an AMD CPU. I didn't try to reproduce it on an Intel unit.
This must be because dsymv corrupts the memory somehow beforehand. But maybe in a different manner still than what manifests itself in the first reported bug.
Just thought this should be reported.
Have a good day,
Michael
michaelkonecny
I retested this on oneAPI 2025.2.
I now get an access violation exception from inside the dsymv subroutine.
It manifests itself on both Debug and Release builds.
It also happens on both AMD and Intel CPUs.
The CPUs I tested it on were:
 - AMD EPYC 7502P
 - Intel Core i7-10750H
Therefore the issue is likely unrelated to [BUG] dsymv corrupts the xmm7 register on AMD processors  and still needs to be addresseed.
Thank you
michaelkonecny
The topic should be renamed to "[BUG] access violation after dsymv call" as it no longer seems to be debug-build or AMD specific.
Fengrui
It looks the code is calling dsysv the way it should be calling dsysv_f95.
